23282 Discussions
Intel hd 4600 graphics not supported widescreen (windows 10)?
KAsma
Intel HD 4600 graphics, windows 10 pro, NEC monitor MultiSync EA221WMe. Widescreen not working.
Hello asmany,
Thank you for joining the Intel communities.
I will appreciate if you could reply with the following information to better assist you.
Intel SSU (System Support Utility): (Note – This is a new Intel tool that will eventually incorporate gathering all the data needed in one click.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Download the utility
Run the exe and select 'Scan'
Save and include as an attachment in the Intel Community Forum.
DxDiag Instructions:
Click on the "Start Menu" -> Type "DxDiag" -> Press "Enter" -> Wait for the DirectX Diagnostic Tool to finish loading.
In the DirectX Diagnostic Tool, click "Save All Information" -> Save the file DxDiag.txt
Include DxDiag.txt as an attachment in the Intel Community Forum.
As well I will apreciate if you could attach a picture of the problem you are having.
Ivan
I'm just following on this thread to ask you if you still need our assistance or if your issue has been resolved.
Ivan
