I have installed the driver several times but the intel hd 630 driver installed but not working. there is some error shown in the intel HD driver 630 control panel like your windows 10 not supported intel HD 630 driver and non-intel HD driver. how to resolve all these problems.
Regard's
Vinay
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
I uploaded all the files as per your suggestion. Please resolved all my problems.
Hello @Decen
In order to check this better, could you please elaborate more regarding what are the specific issues that you are experiencing? Is the system having performance or crashing issues? Do you have issues configuring settings on the Intel® Graphics Command Center? etc?
Based on the Intel® System Support Utility report and the Intel® Graphic Command Center screenshots, we noticed that your system is equipped with a discrete video card NVIDIA GeForce 210* and it seems both the Intel® Graphics and NVIDIA® discrete graphics are enabled.
Regarding the behavior and the message that you are getting "Some features are not supported on non-Intel adapters", this is expected when both graphics controllers (cards) are enabled. The Intel® Graphics Command Center is targeted to manage the Intel® Graphics controller and this message is just an indication that the discrete/secondary Graphics Controller (Graphics card) has been detected, and this doesn't represent any problem. To manage and apply configurations for the third-party discrete graphics, for instance, Nvidia*, you should use the software that they provide or the software provided by your computer manufacturer (OEM).
For any other inquiries, please don't hesitate to contact us back.
Andrew G.
Hi there , I had same concern but not issue with alot configuration of bios and driver to possible steps
first of all i do not think this is an software bug , as i recall the term embed gfx used in two scenarios first
dual bios chipset side gfx and then laptop low consume power gfx , first one is old enough not to be the case
anymore as gfx is emded in cpu rather chipset now but still there, the second type but had constitutionally question about
how to manage itself in case of heavy software and switching to gfx plus possible side load PCI PEG gfx such as nvidia so avoid
windows power manager at most to do not get caught there second go to bios and see where is the system boots
if you got high hand over software load on HD gfx set it to boot up there, and if you desired a modular heavy load boot
from beginning then set it on GFX but i m not sure you be able to see Embded again although might be a better gfx
add virtaul ram in MYCOMPUTER /PROPERTIS/ABOUT/SYSTEM/ADVANCED PERFORMANCE
and add at least 80 GIG ram there to backend no ram HD graphics
although watch for directx12 and shader load dependency and which game needs which to be choosed as gfx work
subdirectry as an example put shader/shadow high texture gfx processing on PEG PCI Directx11/openGL GFX and DirectX12
high teck games on INTEL HD Embded GFX
Hello Decen
We are checking this thread and we would like to know if you need further assistance. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
Hello Decen
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
