23282 Discussions
Iris 5100 and win 10 on bootcamp Mac Mini problems
LLee30
This is with the game SWTOR and the support forums there and Bioware Tech support said I had to come here for help
Bioware says its not their problem but a driver issue... Note that the game was fin on this computer under windows 8.1 (aside from a problem that was "fixed" by setting the shader to low in the games graphic options)
Is there anything i can do other than wait for an new driver to be released? Is there a beta driver that I can try to see if it fixes the problem?
I just found a slightly newer driver
64bit - win64_15407.4279.exe
but the problem remains exactly the same as before 3 restarts of the driver and then the driver is locked out
The full thread on the isssue can be seen at
http://www.swtor.com/community/showthread.php?t=837679 STAR WARS: The Old Republic - After Win 10 UD from 8.1 fails to launch and BSD of VIDEO_TDR FAILURE (idgkmd64.sys)
That thread title was from the original problem and was seen after login to Char select I then changed the driver that Windows 10 install provided which I think was older than the the one I have been working with this weekend
BSD with VIDEO_TDR FAILURE (idgkmd64.sys) the online search on this problem msg. said to be sure video drivers are up to date so I ran the Intel driver update utility and installed the Intel Iris Graphics 5100 driver version 10.18.15.4256 of 7/17/2015
and I get the
"The best driver software for your device is already installed"
" Windows has determined the driver software for your device is up to date"
I then got and ran Intel(R) Driver Update Utility 2.2 and installed again and it seems to be the same one though the date is now 08/05/2015
as you can see here
Version: 15.40.4.64.4256 (Previously Released)
Date: 08/05/2015
Language: English
Operating Systems: Windows® 10, 64-bit
All of this caused the original BSD error outlined above to what it now does as outlined below
a problem is seen when I hit play next to a char name at char select or if I enter the game and then enter a conversation with a NPC i get what you see below noth this is on a Win 10 machine not win 8(R) as the msg states I append a fresh DXdiag at the end of this msg
Display driver stopped responding and has recovered
Display driver Intel HD Graphics Drivers
for Windows 8(R) stopped responding
and has successfully recovered
The above Msg is seen three times and it looks like this
this warning popup( with the Yellow X in a circle at the left top of the pop up) in the lower right corner blanks and reappears Three times and is replaced by another popup of the same sort in the same place
Application has been blocked from accessing Graphics hardware
Application swtor.exe has been blocked from accessing Graphics hardware
At which point the game is frozen and must be quit from the task bar.
System Information
Time of this report: 9/26/2015, 14:17:58
Machine name: MINI-PC
Operating System: Windows 10 Home 64-bit (10.0, Build 10240) (10240.th1.150819-1946)
Language: English (Regional Setting: English)
System Manufacturer: Apple Inc.
System Model: Macmini7,1
BIOS: MM71.88Z.0220.B03.1506051117
Processor: Intel(R) Core(TM) i7-4578U CPU @ 3.00GHz (4 CPUs), ~3.0GHz
Memory: 16384MB RAM
Available OS Memory: 16260MB RAM
Page File: 3838MB used, 15365MB available
Windows Dir: C:\WINDOWS
DirectX Version: 12
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10240.16384 64bit Unicode
Display Devices
Card name: Intel(R) Iris(TM) Graphics 5100
Manufacturer: Intel Corporation
Chip type: Intel(R) Iris(TM) Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0A2E&SUBSYS_0141106B&REV_09
Display Memory: 8242 MB
Dedicated Memory: 112 MB
Shared Memory: 8130 MB
Current Mode: 1920 x 1200 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: LED Cinema
Monitor Id: APP9236
Native Mode: 1920 x 1200(p) (59.950Hz)
Output Type: Displayport External
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd 12umd64.dll,igdumdim32,igd10iumd32,igd10iumd32,igd 12umd32
Driver File Version: 10.18.0015.4279 (English)
Driver Version: 10.18.15.4279
DDI Version: 12
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 2.0
Graphics Preemption: Primitive
Compute Preemption: Thread group
Miracast: Supported
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 8/24/2015 13:38:24, 35975320 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-496E-11CF-6C63-4E21B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0A2E
SubSys ID: 0x0141106B
Revision ID: 0x0009
Driver Strong Name: oem76.inf:5f63e534a8278551:iHSWM_w10:10.18.15.4279 ci\ven_8086&dev_0a2e
Rank Of Driver: 00D12001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
LLee30
Please note that the error msg are calling out a display driver for Windows 8(R) even though this is on a windows 10 64 computer. Could there be parts of the windows 8 driver that failed to be removed when the computer was changed from 8.1 64 to 10 64?
is there any hope of a fix for this? SWTOR was fine on this computer under Win 8.1 64 except the shader setting had to be set to Low.
At which point SWTOR is frozen and must be quit from the task bar.
Kevin_M_Intel
Hello Windshadow,
The latest drivers can be downloaded at this link:
https://downloadcenter.intel.com/ https://downloadcenter.intel.com/
Since you are using a Mac System, you must contact Apple Directly since the support will be provided by them only.
