23257 Discussions
Iris Pro 6200 + World of Tanks= ARTEFACTs
OHilg
Bug in driver Iris Pro 6200 ? viz screenshots http://www.imagebam.com/gallery/dfkkozmdp77cyrjekic74gbke5xdp033 Fast, Free Image Hosting - ImageBam ( config. pc: Core i5-5675C, board Asus Z97-C, RAM 8x 4GB Crucial Bal. Sport) .... what is wrong ?
IUman
Hello ohtm,
Thank you for joining the Intel communities.
Honestly I'm not able to see what exactly the problem is on the image, could you please let me know with more detailed information what exactly the problem is?
As well, could you please upload the Intel® Graphics Driver Report? You can follow the steps to upload the report here:
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics Drivers — Intel® Graphics Driver Report
Also, try installing the latest https://downloadcenter.intel.com/product/89174 Intel® Graphics driver.
Regards!
OHilg
OHilg
my version drive is 10.18.15.4279. this is last ?
IUman
Hello ohtm,
Could you please provide me with the information I requested above?
That is not the latest driver but you can download the latest driver here:
https://downloadcenter.intel.com/product/89174 Downloads for Intel® Iris™ Pro Graphics 6200 for 5th Generation Intel® Core™ Processors
OHilg
last driver 20.19.15.4300 and still artefacts 😞
OHilg
OHilg
Intel(R) Iris(TM) Pro Graphics 6200
Report Date: Tuesday, November 03, 2015
Report Time [hh:mm:ss]: 11:42:16 PM
Driver Version: 20.19.15.4300
Operating System: Windows* 7 Ultimate(6.1.7601)
Default Language: Czech (Czech Republic)
Physical Memory: 31675 MB
Vendor ID: 8086
Device ID: 1622
Device Revision: 0A
Video BIOS: 1030.0
Current Resolution: 1920 x 1200
Processor: Intel(R) Core(TM) i5-5675C CPU @ 3.10GHz
Processor Speed: 3098 MHz
Processor Graphics in Use: Intel(R) Iris(TM) Pro Graphics 6200
Shader Version: 5.0
OpenGL* Version: 4.4
OpenCL* Version: 2.0
* Microsoft DirectX* *
Runtime Version: 11.0
Hardware-Supported Version: 11.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Television *
Display Type: Digital
Serial Number: CZQ8140829
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: HDMI
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 20.47 inches
Vertical Size: 12.6 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 576 (50p Hz)
720 x 480 (60i Hz)
720 x 960 (60i Hz)
720 x 576 (50i Hz)
720 x 480 (60p Hz)
800 x 600 (75p Hz)
800 x 600 (60p Hz)
832 x 624 (75p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 870 (75p Hz)
1280 x 720 (60p Hz)
1280 x 960 (60p Hz)
1280 x 720 (50p Hz)
1280 x 1024 (75p Hz)
1440 x 900 (60p Hz)
1600 x 1200 (60p Hz)
1600 x 1000 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60p Hz)
1920 x 1080 (50p Hz)
1920 x 1200 (60p Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (60i Hz)
Power Management Support
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 22 F0 CF 26 01 01 01 01
0E 12 01 03 80 34 20 78 EE B5 35 A5 56 4A 9A 25
10 50 54 A5 6B 80 81 C0 81 40 95 00 A9 00 B3 00
A9 40 D1 00 01 01 28 3C 80 A0 70 B0 23 40 30 20
36 00 06 44 21 00 00 1A 00 00 00 FD 00 30 55 18
5E 14 00 0A 20 20 20 20 20 20 00 00 00 FC 00 48
50 20 77 32 34 30 38 0A 20 20 20 20 00 00 00 FF
00 43 5A 51 38 31 34 30 38 32 39 0A 20 20 01 A9
02 03 1B F1 23 09 07 07 48 84 02 01 10 16 11 07
1F 83 01 00 00 65 03 0C 00 10 00 8C 0A D0 8A 20
E0 2D 10 10 3E 96 00 06 44 21 00 00 98 8C 0A D0
90 20 40 31 20 0C 40 55 00 06 44 21 00 00 18 01
1D 80 D0 72 1C 16 20 10 2C 25 00 06 44 21 00 00
9E 01 1D 00 BC 52 D0 1E 20 B8 28 55 40 06 44 21
00 00 1E 01 1D 80 18 71 1C 16 20 58 2C 25 00 06
44 21 00 00 9E 00 00 00 00 00 00 00 00 00 00 A3
* Other names and brands are the property of their respective owners.
IUman
In this case, please wait for a new graphics driver version to come up and meanwhile I recommend keeping Windows updated and all of the drivers.
OHilg
The last driver ( 15.40.12.4326 ) and the problem is still the same
What's next ?
IUman
Hi ohtm,
We appreciate all your feedback and your patience on this issue.
In order to fix this issue and to escalate to engineering I will appreciate if you could fill out the information at the following link:
/thread/77761 https://communities.intel.com/thread/77761
Once you fill out the information please post it here so we can escalate it to engineering.
JSeko
Hello, did you find any solution to this problem? We solve the same bug with a friend. 😞
Thank you,
Jiri
(CZE, Brno)
IUman
Please try with this Beta driver you can download it here:
https://downloadcenter.intel.com/download/25541/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40- Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
If the Beta driver does not work then we will need to wait for a new driver to be release that hopefully will be fixing this kind of problems.
Ivan
OHilg
this driver (Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40] ) solves nothing ...again
intel waiting to be outdated hardware or game ?? !
IUman
This is the Beta driver that it was recently released, please try this one:
https://downloadcenter.intel.com/download/25848/Intel-Beta-Graphics-Driver-for-Windows-7-8-1-10-15-40-?v=t Download Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40]
I'm not sure if this is the one you already tried but if you did please let me know.
IUman
In this case we will need to wait for a new driver version; you can check the https://downloadmirror.intel.com/25848/eng/ReleaseNotes_GFX_15%2040%204404.pdf release notes for this driver and see the known issues, we are aware of the issues with World of Tanks*
Ivan
OHilg
I would hope that any time soon ...
kkamo2
I have the same problem witg 5675c
IUman
I'm sorry about the issue you have, as you can see on the release notes we are aware of some issues related with world of tanks, at this point we will need to wait for new version of drivers to come up that hopefully will fix issues like this.
Ivan
HPham10
I confirm this issue, plz fix this
OS: Windows 10 build 10586.14
Driver: 15.40.12.4326 beta
