sorry for my rookie english, I´m from Germany.
Today I´d installed my new i5-5675C and at first glance almost everything seems to run fine.
But my Iris Pro 6200 GPU doesn't idle, it always run at full 1100 MHz, also at 2D/Windows Desktop.
Only if I go to Intel graphic preferences and set energy options from "Balanced" (=Default) to "Battery
Saving", the GPU clocks down to 500 MHz. If I go back to "Balanced", it still holds 500 MHz.
BTW why 500 MHz, default Pro 6200 idle clock are 300 MHz? But 300 are only reachable with
Windows "Standard VGA Adpater", not with Intel driver -> also very curious...
After that I start a 3D game, quit it, back to Desktop -> GPU runs at durable 1100 MHz again.
If I keep "Battery Saving" this has no effect, as soon as I start+close a 3D software or reboot Windows,
GPU runs at constant 1100 MHz again, although "Battery Saving" is still selected.
Tried out all available Intel graphic driver versions, all with the same result. It doesn´t run any
software/background task which would load GPU all the time. Windows 7 GPU energy options
are automatically adjusted to the settings I choose at the Intel graphic/energy preferences.
By the way, the CPU idles fine at Desktop, only the GPU runs with full throttle all the time.
Is there any other Broadwell user here who can make the same detection? Thank you for every
statement or hint what I can do/try out now.
My system
ASRock Z97E-ITX/ac Mainboard
latest UEFI/BIOS P2.00 (Beta)
Intel Core i5-5675C
2x4 GB Corsair DDR3-2133 @ 2400 MHz @ 1.5000V
Windows 7 (64) Home Premium with newest updates
Hello AX-Turbo,
Checking the information you posted, it seems that your system is working fine. The processor you have http://ark.intel.com/products/88095/Intel-Core-i5-5675C-Processor-4M-Cache-up-to-3_60-GHz Intel® Core™ i5-5675C Processor (4M Cache, up to 3.60 GHz) Specifications, it has a graphics base frequency of 300 MHz and a graphics max dynamic frequency of 1.1 GHz which is the equivalent of 1100 MHz that you mentioned, if you trying to change that parameter that will depend on the V-BIOS on your motherboard, you might need to check with ASRock about this matter.
Amy.
Ok that's a helpful hint, thank you.
Nevertheless, if coincidentally another ASRock Z97E-ITX/ac user with the same issue reads
this, please respond. Can´t believe that I´m the only one who noticed this problem.
this post also relates to the same problem
for laptops the base clock rate is set by the registry option intLVDSSwingSetting
Hello zeqzy,
Thank your for sharing that information.
Amy.
Hello zeqzy and thank you for your answer.
I´ve found this entry 'intLVDSSwingSetting' about ten or twelfe times at my registry, all containing the value '0'.
Could it be advisable to enter another value there? Another question is, what value is the real base clock rate
of a Iris Pro 6200, which clocks variable between 300 and 1100 MHz?
Ok I keep this at the back of one's mind, first I´ll wait for lamely ASRock supports answer (if they'll ever answer).
the information is found in the driver inf files
; 0x00 - Medium - Data and Clk Swing set to 298 mV
; 0x01 - High - Data and Clk Swing set to 320 mV
; 0x02 - Low1 - Data and Clk Swing set to 144 mV
; 0x04 - Low2 - Data and Clk Swing set to 170 mV
; 0x08 - Low3 - Data and Clk Swing set to 196 mV
; 0x10 - Low4 - Data and Clk Swing set to 220 mV
; 0x20 - Low5 - Data and Clk Swing set to 247 mV
; 0x40 - Low6 - Data and Clk Swing set to 273 mV
HKR,, IntLVDSSwingSetting,%REG_DWORD%, 0x00
this sets the voltage that is sent to the GPU the BIOS sets the voltage sent to the CPU and the value set here is the share of that power to be sent to the GPU
there is also an option to change the clock rate from what the GPU has set
HKR,, PNMClkDeviation, %REG_DWORD%, 0 ; Clock deviation value which is multiplied by 10.
HKR,, PNMFlags, %REG_DWORD%, 0 ; Bit0: Downward Deviation, Bit1: Upward Deviation. Bit2-31: Reserved.
e.g setting PNMClkDeviation to 20 and PNMFlags to 1 will lower 500 to 300
