can i configure 4 monitors so that they are treated as one large monitor. e.g. if i maximize a window (right top corner), it should not only be displayed maximized on one monitor, but on all 4.
do i need a special driver or a tool?
Hi, Mat_2.
Thank you for posting in our Community.
Yes, you can configure 4 monitors to act as one large monitor. This setup is often referred to as "extended display" or "spanning." However, you will need third-party DisplayPort* splitters to connect four compatible displays for this feature. Could you please confirm or send an image or pictures of what your monitor setup looks like?
Additionally, could you share the exact make and model of your monitor so we can review its specifications? Finally, I'd like to delve deeper and verify specifics like the graphics models, precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable us to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue.
Have a nice day!
Von M.
Hi, Mat_2.
Von M.
Hi, Mat_2.
I have not heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
