23269 Discussions
Is The Intel Arc A750 Compatable With My Motherboard?
Sailir88
I recently received some secondhand parts from a buddy of mine and I was wondering if I could put an A750 in the motherboard
The Motherboard in question is a Asus Z97-AR ATX LGA1150 Motherboard
Jean_Intel
Hello Sailir88
We understand you are looking for information about the compatibility between your motherboard and the Arc Card. The Intel® Arc™ A-Series Graphics motherboard requirements are: Full-size PCI Express 3.0 (or newer) x16 slot and Re-Size BAR Support. Based on your motherboard specifications, the motherboard has 2x PCIe 3.0/2.0 x16, meeting this requirement. About the Re-Size BAR Support, it is implemented on the BIOS. Refer to your system manufacturer's support page for further details.
Not that the BIOS has a significant impact as they are designed to support configuration for a variety of devices. You should contact Asus to confirm if your motherboard BIOS supports these cards.
Also, Intel recommends using 10th gen or newer platforms for the best experience; however, Additional platforms/motherboards with Resizable BAR / Smart Access Memory enabled may also support Intel® Arc™ A-Series graphics.
For further information, please refer to the article 'Intel® Arc™ A-Series Graphics – Desktop Quick Start Guide.'
Jean O.
Jean_Intel
Hello Sailir88,
We hope you are doing fine.
Best regards.
Jean O.
Zidan
Does amd motherboard support arc a750
AlHill
Ask  the AMD motherboard manufacturer.
