22878 Discussions
Kodu Rendering Issue on HD 620 (i5-7200U)
JWrob
Hi
I have a Lenovo Yoga 710 running Windows 10 which has rendering issues when running Kodu (latest version 1.4.164.0). This model does not have dedicated graphics from nvidia - it uses the integrated graphics on the CPU. I have downloaded all of the latest drivers from Lenovo and Microsoft's Windows 10 update but I still have the issue. The latest Intel graphics drivers from Lenovo is 21.20.16.4526 and I have tried Intel's generic graphics drivers 15.4512.4542 and the beta 4552 but this does not resolve the issue.
System Setup Information:
System Used: Lenovo Yoga 710
CPU SKU: i5-7200U
GPU SKU: HD620
Processor Line: U
System BIOS Version: CIUY7 - 2XCN25WW (v2.00) (latest that Lenovo update provided from shipped 2XCN20WW(v1.02)
CMOS settings:
Graphics Driver Version: 21.20.16.4526 (from Lenovo) and Intel's Generic Graphics Drivers 15.4510.4542 and the beta 15.4512.4552
GOP/VBIOS Version: 9.0.1054
Operating System: Windows 10
OS Version: Windows 10 version 1607 (Anniversary Update)
API: DirectX 9c and Shader Model 2.0 (based on system requirements listed https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjSz5nP-LLRAhXMQiYKHV5EChkQFggkMAI&url=https://www.kodugamelab.com/discussion/kodu-community/technical-support/2012/1/kodu-technical-faq/&usg=AFQjCNGAKzn_4wPCKcV1sUsn2U6bK-4eDQ&sig2=2mArKkjamy4zBtfY_oCjKw Kodu Forum | Kodu Technical FAQ)
Occurs on non-Intel GPUs?: I don't know
Steps to Reproduce:
1. Run Kodu 1.4.164.0
2. Try environments shipped that have trees e.g. Fortress Defence
3.
4.
5.
6.
7.
8.
9.
10.
Expected Results:
Trees not rendering across the screen
Actual Results:
See screenshot + video
Additional Information:
Output from intel HD Graphics Control Panel
Report Date: Sunday, January 8, 2017
Report Time [hh:mm:ss]: 4:22:26 PM
Operating System: Windows* 10 Home (10.0.14393)
Physical Memory: 8035 MB
Vendor ID: 8086
Device ID: 5916
Device Revision: 02
Graphics Output Protocol (GOP) Version: 9.0.1054
Current Resolution: 1920 x 1080
Processor: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
Processor Speed: 2712 MHz
Processor Graphics in Use: Intel(R) HD Graphics 620
Shader Version: 5.1
OpenGL* Version: 4.4
OpenCL* Version: 2.1
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 12.0
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Built-in Display *
Display Type: Digital
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: Embedded DisplayPort
Device Type: Built-in Display
Maximum Image Size
Horizontal Size: 12.2 inches
Vertical Size: 6.69 inches
Supported Modes
1920 x 1080 (60p Hz)
I've tried changing all the options in the Kodu settings programme (turning off all visual effects and graphics quality) but this doesn't help.
I have reported the issue to the Kodu team, but suspecting this is a graphics rendering issue I have reported it here as well.
Thanks in advance for your help.
Message was edited by: Jonathan Wrobel
Hello KabyLake,
Thank you for all the information provided.
Please let me review your thread, as soon as I have more information I will update the thread.
Amy.
/thread/110034 KabyLake, I am still working on your case.
I will update your thread as soon as I have more information.
Amy.
JWrob
Hi Amy
I've been in touch with Microsoft about this issue and they believe they might have found the issue. Microsoft have provided me with an unreleased build for testing - and early indicators are that it does indeed fix the problem.
/thread/110034 KabyLake, that is really good to hear! So, you can confirm that is now 100% working?
Amy.
