I have auto select mode enabled. After gaming or using nvidia gpu, the gpu is not going to idle state, because of this the laptop is lagging. To fix this, these are the different ways to fix it
Sign out and sign in to windows
Manually switching gpus ( i.e turning on nvidia gpu only mode and then enabling auto select mode)
Restart the file explorer process in task manager
these are the three different ways to send the gpu to idle again and stop lagging, also idk when it all started to happen but before it started to happen i update intel graphics drivers in optional updates provided by acer only.
I have literally tried everything, clean install of drivers , windows , factory image
still the issue persists please help me fix the issue
Hello @kagami
We sincerely regret you are experiencing issues with your laptop, we will be more than happy to assist you.
Please answer the following:
· Does the issue happen if you disable NVIDIA graphics?
· Have you contacted the System Manufacturer?
Also, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Then, please generate and attach the Report for Intel® Graphics Command Center
Jose B.
@Jose_Intel like why should i disable gpu i want it so that there is better performance, the issue is the dgpu is not switching back to igpu after gaming session, smth keeps the gpu turned on and not allowing the gpu to go to idle I checked everything but nothing is using the gpu.
i can confirm that in predator sense, this all started happened after updating the intel driver in optional updates trying to fix black screen issue in browsers but now stuck in more serious issue u can check in the predator laptop community page. please provide update to the intel driver of this laptop model ph315-55 idk what will fix the issue could be bios update or smth
Hello kagami
We would like to know if you have contacted the system manufacturer regarding this.
Also, we requested to disable NVIDIA graphics only for testing, we need to isolate the issue. Please do it.
Please run the Windows Update tool. Then, try our latest generic driver: Intel® Arc™ & Iris® Xe Graphics - Windows* (Follow these instructions How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver)
Let us know the outcome.
Jose B.
Nope i was unable to contact system manufacturer about this , i gave my laptop to acer authorised service center and they where unable to fix it .
ok will test without the gpu and update, but the thing is that when gaming i need gpu and after that i dont need so i will try to disable it after gaming and check if lag occurs.
The DDU i have done many time of both gpu drivers still couldnt fix the issue even updated to the latest intel driver before. Had some issues so i reverted to laptop support page intel driver version.
I have contacted system manufacturer through mail but they always send me to the service center, who actually dont know how to fix it
And more thing to add when this lag starts occuring i can see that the gpu is not idling i have mux switch in my laptop
next is that sytem process uses gpu 1 copy periodically always never ending idk why only that is using the gpu 1 copy no other process is using so i asked my friend about it he told he can also gpu 1 copy but his laptop gpu is idling back but in mine not
i didnt have this issue before updating the intel driver in optional updates , once i updated it feels like that intel driver did some changes to system files permanently like i cant change it now and gpu is not idling
Hello kagami
Thank you for your reply.
We will research about this issue internally, we will post back as soon as we have any update.
Jose B.
Hello kagami
Thank you for waiting.
Based on the troubleshooting performed so far, we highly recommend contacting the system manufacturer to explore other options since the issue does not seem to be related to the driver.
This thread will no longer be monitored by Intel, thank you for understanding.
Jose B.
just another issue closed in the same way others where with no help thanks a lot man
are u sure its not related to the driver? then why is mux switch not working correcltly as it is supposed to?
