Community
cancel
Showing results for
Search instead for
Did you mean:
형소000
Laptop Auto brightness setting
I updated it with the latest HD620 graphics driver, but the new Intel Graphics Center was installed and it was not a UI I used before. The older version of the old graphics control center was able to disable the auto brightness option on the power tab, but this latest version does not have a power tab, so I can not turn off the auto brightness setting.
Any solution?
AlHill
Always use the driver provided by the laptop manufacturer, which is likely customized/modified for your laptop hardware.
Doc
