23081 Discussions
Laptop stürzt ab währrend Grafiktreiber installation
flozirkus
I've got an HP 15-ap102ng with Intel(R) Core(TM) i5-7200U with Win10 Home 64bit installed. Acc. datasheets of the laptop an Intel® HD Graphics 620 should be integrated.
After / during a Win update last fall, to my mind to 21Hx, the laptop crashed (turned on but fully black screen). I made it run again only with a new win installation (21Hx), but could not install the right graphic driver, neither with HP nor with Intel installation tool nor manual - everytime the screen turns black during installation and only a hard reset makes it run again. After that it starts with the basic win graphic driver.
I did several times a full Memorytest without any problems.
As a next step I would try to make a new win 10 installation with 20Hx version. However before make the efforts I hope there are some more ideas or recommendations.
Thanks and BR
Florian
LeonWaksman
Hi Florian,
Your processor is equipped with  Intel® HD Graphics 620 integrated GPU, but according to specification your laptop is equipped with discrete AMD Radeon™ R5 M430 Graphics  as well. In this case probably the integrated GPU is disabled by default in BIOS. So, if I'm right, you need to install the AMD Graphics DriverThis is the driver download page for your laptop.
Leon
flozirkus
Hi Leon,
thanks for your fast reply.
I recognized I had a spelling mistake in the laptop ID: it is an 15-aq102ng and entering this on the HP support sides only offers the intel drivers so I guess there is no additional graphic card installed.
I tried (again) to install each of these drivers all resulting with my screen getting black and only leaving me doing a hard reset:
Looking forward to more ideas.
THanks in advance
David_G_Intel
If I may offer input here, if you have already tried a clean install of the OEM drivers, it is recommended that you check with them for additional steps, as those drivers include customizations that the generic Intel drivers do not.
David G
flozirkus
Hi David,
thanks for your feedback - just to ensure I understand you well:
by "them" you mean to check with HP?
Florian
David_G_Intel
Yes, HP is the system manufacturer and we recommend contacting their support directly.
David G
