22878 Discussions
Laptop with Intel HD 4600: screen blinking dark sometimes
TWozn1
Hi there.
I just started using a MSI GE40 laptop with intel HD 4600 and a NVIDIA graphics (in optimus mode I believe).
There is an annoying bug that the screen every now and then blinks dark (I guess it's a single black frame, but have no way to verify it). The blinking is of low intensity (i'd say maybe a few times a minute at most) and correlates with on-screen activities. When I do nothing and the screen does not change, this seems not to happen.
All the relevant drivers are the latest: intel iGFX is 10.18.10.3907, NVIDIA card is 9.8.13.4411. I had this with .3496 for intel and .332.35 NV as well. I tried disabling the optimus either way (so that either card is the only active) - didn't go away. I tried disabling the devices in device managed, one at a time, same result.
What seems to have helped is to disable "Automatyczne odswiezanie panelu" in "Zasilanie" under "Zasilanie z baterii" through "Panel strowniczy grafiki HD Intel(r)" (an app). I do not feel like misguiding you by providing possibly incorrect translation, sorry for that.
BTW MSI provides a BIOS UEFI update that has a description of "fix panel that have PSR function happen flash sometimes under DC mode", but I am unwilling to verify what it means if the outcome of applying it erroneously could be "(...) Failure to abide may result in bricking your system."
Best regards
Tomasz Wozniak
Kevin_M_Intel
Hi TadzioPazur,
Let me help you with that.
Based on all the information you have provided, I would like you to do the following troubleshooting steps:
  1. Uninstall the Intel® graphics driver and install the latest one we have at this location:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24245&lang=eng&ProdId=3720 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24245&lang=eng&ProdId=3720
If you get messages during the installation, try the steps here:
/docs/DOC-22542 https://communities.intel.com/docs/DOC-22542
  1. Make sure you update all drivers for Nvidia Graphics driver.
  1. Updating the BIOS on your computer can help solving the issue.
Kevin M
