23092 Discussions
Latest N-series (Braswell, e.g. N3700) HD Graphics driver for Windows 10, 32-bit?
xxav
I'm looking for the latest drivers for the Intel N-series (Braswell) HD Graphics for Win10 32 bit.
Is it really the case that the last drivers are https://downloadcenter.intel.com/download/25149/Intel-HD-Graphics-Production-Driver-for-Windows-10-32-bit-N-Series-?product=87261 Download Intel® HD Graphics Production Driver for Windows* 10 32-bit (N-Series) ? That's from July 2015! (15.40.1.4256) but it does show the download is valid for https://downloadcenter.intel.com/product/87261/Intel-Pentium-Processor-N3700-2M-Cache-up-to-2-40-GHz- Intel® Pentium® Processor N3700 (2M Cache, up to 2.40 GHz)
Drivers like this one https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=80939 Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40] (15.40.28.4501 (Latest)) don't list "Intel(R) HD Graphics" (without a number) under "This download is valid for the product(s) listed below."
like the GPU is listed in my Device Manager.
This is what the Intel Driver Update Utility 2.6 shows: https://i.imgur.com/dFswobH.png https://i.imgur.com/dFswobH.png
Which is confusing, since it offers both drivers I linked above. But as I've said: on the 15.40.28.4501 page the N3700 Pentium is not listed as supported.
Additional information: In my Device Manager, the GPU is listed with hardware ID
PCI\VEN_8086&DEV_22B1&SUBSYS_101A1D05&REV_21
The laptop this thing is in is very slow with web browsing (scrolling even) and HD movies, so I suspect there's something wrong with the hardware acceleration of the GPU, which is why I want to try the latest drivers.
Stefan3D
Search your GPU at MS update catalog:
http://www.catalog.update.microsoft.com/Search.aspx?q=VEN_8086%26DEV_22B1 http://www.catalog.update.microsoft.com/Search.aspx?q=VEN_8086%26DEV_22B1
20.19.15.4531 - 81,3 MB seems to be the latest
Take it or find a full installer elsewhere...
xxav
1) I don't think that's the correct driver for the Pentium N3700's graphics chip.
If I look at the Supported Hardware IDs tab of all those driver packages they usually go down to the SUBSYS (VEN_8086&DEV_22B1&SUBSYS_101A1D05) instead of just the VEN and DEV.
Also, why wouldn't Windows 10 X86 just auto install that driver then if it was in the MSU repository? I checked for updates with Windows Update to no avail and it's not listed on Downloadcenter.Intel.com either. Why wouldn't Intel's Driver Update Utility recommend this driver, too?
2) It seems that driver is bugged (
3) What's the difference between:
Intel Corporation driver update for Intel(R) HD Graphics Windows 10 and later drivers,Windows 10 and later upgrade & servicing drivers Drivers (Video) 9/29/2016 20.19.15.4531 81.3 MB Intel Corporation - Graphics Adapter WDDM1.1, Graphics Adapter WDDM1.2, Graphics Adapter WDDM1.3, Graphics Adapter WDDM2.0 - Intel(R) HD Graphics Windows 10 and later drivers Drivers (Video) 9/29/2016 20.19.15.4531 81.8 MB
If I decide to take the risk which one do I need?
Stefan3D
1) drivers w/o SUBSYS_IDs are generic, those with SUBSYS_IDs are probably customized and/or tested for a particular vendor.
I have no idea how MS auto update or Intel's utility make their decisions.
2) / 3) both CAB files seem to have the same content
To be on the safe side create a https://support.microsoft.com/en-us/instantanswers/e6bbddb0-9db4-4d88-9063-42c52c79a96e/create-a-system-restore-point "system restore point" before installation.
Hello:
Thank you very much to Stefan3D for providing all the information above.
To xavdeman:
In regard to your inquiry, yes, as you mentioned before the latest driver for the Intel® N3700 processor is the one released back in July 2015.
To answer your second question, both drivers are the same, the actual version on the driver is listed on the last 4 digits of it, so if the last 4 numbers are the same like: 4531, it means it is the same driver even if the description on it is different.
You can always try driver 4501 or 4531, the PC will not suffer any damage, worst case scenario the driver will not get installed, and you can also install it or un-install it manually:
Install graphics manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html
Un-install graphics manually:
http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html
Also you can always disable the Windows® 10 driver updates:
http://www.howtogeek.com/223864/how-to-uninstall-and-block-updates-and-drivers-on-windows-10/ http://www.howtogeek.com/223864/how-to-uninstall-and-block-updates-and-drivers-on-windows-10/
Alberto
