23256 Discussions
Latest driver 32.0.101.6913 removes customizable graphics settings from the Iris Xe!
AliAkbar2005
Greetings,
After installing the latest Intel driver, I can no longer tweak graphics settings in Intel Graphics Software, settings such as Image Sharpening & Anisotropic Filtering. Now when navigating to the "Graphics" tab, it simply says "Your current hardware doesn't support any graphics features."
But it does, I was able to change them and also see their effects in games, so why does it say that now? Is this a driver bug, or did Intel remove/disable those features for the Iris Xe, if so, why? The release notes say nothing about this either.
The only workaround for now is to rollback/reinstall 32.0.101.6881, doing so brings back the customizable graphics settings (and they work fine too, tested on some games)!
I have attached screenshots of the "Graphics" tab in Intel Graphics Software, one from driver 32.0.101.6881 and the other from 32.0.101.6913.
Thanks in advance!
Guicrz-insp_35
I'm also having this issue, in my case, only displaying frame sync for the UHD Graphics:
Additionally, the Display tab is not loading for me, stuck on this loading screen, not only completely inaccesible, but it greys out all the other tabs:
CaNeBuRy23
New Contributor II
hey mate yes, this issue does not occur in driver version 32.0.101.6881, where all customizable graphics features remain accessible and fully functional. The message stating “Your current hardware doesn’t support any graphics features” in 32.0.101.6913 is most likely due to a driver-related bug or misdetection.
If you're experiencing difficulties adjusting color correction or other graphics settings particularly after applying a display scheme it is advisable to update your Intel® Graphics Driver to the latest supported version for your system. this can help restore full functionality.
You may also refer to this Intel article for additional guidance:
👉Intel Graphics Settings Not Working – Troubleshooting Guide
Guicrz-insp_35
