Community
cancel
Showing results for
Search instead for
Did you mean:
manster6475
Lenovo T460 Intel(R) Graphic 520 3440x1440 refresh limited to 50Hz
I have a Lenovo T460 with Intel(R) Graphic 520 and Lenovo screen G34w-10 . I manage to get  3440x1440 resolution but I do not seem to get refresh above 50Hz what is the reason? I use a 2.1 HDMI.
Below is the report.
Thanks in advance.
Manster6475
Report Date: Friday, 29 January, 2021
Report Time [hh:mm:ss]: 07:00:52
Driver Version: 26.20.100.7812
Operating System: Windows* 10 Enterprise (10.0.17763)
Physical Memory: 20335 MB
Vendor ID: 8086
Device ID: 1916
Device Revision: 07
Graphics Output Protocol (GOP) Version: 9.0.1046
Current Resolution: 3440 x 1440
Processor: Intel(R) Core(TM) i7-6600U CPU @ 2.60GHz
Processor Speed: 2808 MHz
Processor Graphics in Use: Intel(R) HD Graphics 520
Shader Version: 5.0
OpenGL* Version: 4.6
OpenCL* Version: 2.1
Vulkan* Version: 1.2.131
* Microsoft DirectX* *
Runtime Version: 12.0
Hardware-Supported Version: 11.1
* Devices connected to the Graphics Accelerator *
Active Displays: 1
* Digital Television *
Display Type: Digital
Serial Number: UGW03DPN
DDC2 Protocol: Supported
Gamma: 2.2
Connector Type: DisplayPort
Device Type: Digital Television
Maximum Image Size
Horizontal Size: 31.5 inches
Vertical Size: 12.99 inches
Supported Modes
640 x 480 (60p Hz)
640 x 480 (72p Hz)
640 x 480 (75p Hz)
720 x 400 (70p Hz)
720 x 480 (60p Hz)
720 x 576 (50p Hz)
800 x 600 (56p Hz)
800 x 600 (60p Hz)
800 x 600 (72p Hz)
800 x 600 (75p Hz)
832 x 624 (75p Hz)
1024 x 768 (70p Hz)
1024 x 768 (60p Hz)
1024 x 768 (75p Hz)
1152 x 864 (75p Hz)
1280 x 720 (60p Hz)
1280 x 720 (50p Hz)
1280 x 1024 (75p Hz)
1280 x 1024 (60p Hz)
1280 x 1024 (70p Hz)
1366 x 768 (60p Hz)
1440 x 900 (60p Hz)
1600 x 900 (60p Hz)
1680 x 1050 (60p Hz)
1920 x 1080 (60i Hz)
1920 x 1080 (50i Hz)
1920 x 1080 (50p Hz)
1920 x 1080 (120p Hz)
1920 x 1080 (60p Hz)
2560 x 1440 (60p Hz)
3440 x 1440 (100p Hz)
3440 x 1440 (60p Hz)
3440 x 1440 (50p Hz)
Power Management Support
Standby Mode: Supported
Active Off Mode: Supported
Raw EDID:
00 FF FF FF FF FF FF 00 30 AE A1 66 00 00 00 00
26 1E 01 03 80 50 21 78 B6 EE 95 A3 54 4C 99 26
0F 50 54 AF EF 00 81 C0 81 80 95 00 A9 C0 B3 00
D1 C0 71 4F 81 8A F5 7C 70 A0 D0 A0 29 50 30 20
35 00 1D 4E 31 00 00 1A 00 00 00 FF 00 55 47 57
30 33 44 50 4E 0A 20 20 20 20 00 00 00 FD 00 30
64 17 A0 3C 00 0A 20 20 20 20 20 20 00 00 00 FC
00 4C 45 4E 20 47 33 34 77 2D 31 30 0A 20 01 08
02 03 31 F3 4B 01 02 03 04 05 90 12 13 14 1F 4E
23 09 07 07 83 01 00 00 67 03 0C 00 10 00 38 42
67 D8 5D C4 01 78 80 00 68 1A 00 00 01 01 30 64
ED 44 D0 70 A0 D0 A0 29 50 58 40 45 00 1D 4E 31
00 00 1E 66 21 56 AA 51 00 1E 30 46 8F 33 00 1D
4E 31 00 00 1E 6A 5E 00 A0 A0 A0 29 50 30 20 35
00 1D 4E 31 00 00 1E 22 68 70 A0 D0 A0 29 50 30
20 35 00 1D 4E 31 00 00 1A 00 00 00 00 00 00 81
Victor_G_Intel
Hello manster6475,
To better assist you please provide the following report and information to continue with your support request.
-Please run the following tool and attach the report generated.
Intel® System Support Utility (Intel® SSU)
Download link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
•          Open the application and click on "Scan" to see the system and device information
•          By default, Intel® SSU will take you to the "Summary View".
•          Click on the menu where it says "Summary" to change to "Detailed View".
•          To save your scan, click on "Next", then "Save".
* Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
- Is this the first time that you try to set up that resolution (3440x1440) at that refresh rate (50Hz) or were you able to use it before? If yes, was there any recent change related to the point when the issue started?
-  Are you using a straight-through connection (e.g. HDMI-to-HDMI, DVI-to-DVI) with a single cable? Or are you using any type of video adapters, converters, or dockings? Please provide details.
-Have you check with the display’s manufacturer to see if you have the latest patch update, driver, and firmware for that monitor?
I look forward to hearing from you.
Victor G.
Victor_G_Intel
Hello manster6475,
Please let me know if you need further assistance.
Victor G.
Victor_G_Intel
Hello manster6475,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer be monitored
Victor G.
