ICS_FeedItem_Trigger: execution of BeforeDelete caused by: System.DmlException: Update failed. First exception on row 0 with id 5000P00000qQlTJQA0; first error: OP_WITH_INVALID_USER_TYPE_EXCEPTION, Operation not valid for this user type: [] Class.ICS_FeedTriggerStatusUpdate_Handler.updateCaseStatusOnCommunityFeedItemDelete: line 149, column 1 Trigger.ICS_FeedItem_Trigger: line 81, column 1
Explain in detail what your problem and question is.
Also, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
W10 2004, W10 May 2020, W10 20H1, W10 19041 - A rose, by any other name, still smells.
