22949 Discussions
Mass Effect 2 crashes with HD Graphics 3000
Steps to reproduce the issue:
1) Install and start Mass Effect 2 (I downloaded it from Steam)
2) While in play, press the Esc button to access the game menu
3) The game crashes with an error in igdumd32.dll
The problem is systematic.
The system is a Lenovo L520 with Intel HD Graphics 3000, running Windows 7 Professional 64-bit, with the latest available graphics driver, version 8.15.10.2509 (version .2559 is not available from Intel web site anymore, as far as I can tell).
Intel reports the game as playable with HD Graphics 3000, see http://www.intel.com/support/graphics/intelhdgraphics3000_2000/sb/CS-032052.htm http://www.intel.com/support/graphics/intelhdgraphics3000_2000/sb/CS-032052.htm
I have seen other users reporting the same issue. Is there any known workaround, or a fix coming up from Intel?
Thanks!
Here below the crash report from Windows and the system configuration:
Problem signature:
Problem Event Name: APPCRASH
Application Name: MassEffect2.exe
Application Version: 1.2.1604.0
Application Timestamp: 4bd611db
Fault Module Name: igdumd32.dll
Fault Module Version: 8.15.10.2509
Fault Module Timestamp: 4e5e8fd6
Exception Code: c0000005
Exception Offset: 0005c570
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
Additional Information 1: 01bf
Additional Information 2: 01bf342c2a3a9018ca1b1e44ba5fecdd
Additional Information 3: 7bdd
Additional Information 4: 7bdd70dc18e92aafb112222b6e71d745
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409 http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Here the system configuration:
Intel(R) HD Graphics 3000
Report Date: 1/10/2012
Report Time[hr:mm:ss]: 23:14:31
Driver Version: 8.15.10.2509
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: Italian (Italy)
DirectX* Version: 10.1
Physical Memory: 8032 MB
Minimum Graphics Memory: 128 MB
Maximum Graphics Memory: 1760 MB
Graphics Memory in Use: 215 MB
Processor: Intel64 Family 6 Model 42 Stepping 7
Processor Speed: 2494 MHz
Vendor ID: 8086
Device ID: 0126
Device Revision: 09
the only known fix is to use an older driver (2361).
This workaround for Rage+Steam was recently posted on the forum: /servlet/JiveServlet/download/140911-35573/Rage Workaround.docx http://communities.intel.com/servlet/JiveServlet/download/140911-35573/Rage%20Workaround.docx
I am finding the same workaround allows to hit Esc and go to the in-play meny of Mass Effect 2 without issues. I haven't had a chance to progress further in the game yet, but the workaround proposed for Rage could also apply to ME2.
