what ist the maximum refresh rate of the NUC12WSHi5 at Displayport with FHD or 4k resolution? (not interested in max. resolution, it's 8k/60Hz)
Supports Displayport HDCP 2.3 or only the HDMI port?
Kind regards
Hello deeepy,
Thank you for posting on the Intel® communities. I understand that you have an inquiry related to the Intel® NUC 12 Pro Kit NUC12WSHi5.
In this case, the Intel® NUC 12 Pro Kit NUC12WSHi5 supports HDMI 2.1 and DP 1.4a. However, I will investigate the max frequency supported at Full HD and 4K.
I will get back to you as soon as possible.
Deivid A.
Hello Muc,
thank you for your hint. So I have some facts about the Display Port 🙂
deeepy
Hello deeepy,
Thanks for your patience. I would like to let you know that HDCP 1.4 and 2.3 is supported via both HDMI and DP ports.
Also, the NUC will support what the Processor (Graphics) can handle. Since the graphics support HDMI 2.0/DP1.4 Full HD should not be a problem. Keep in mind that the Max HDMI resolution supported is 4096x2304 at 60Hz and the Max DP resolution is 7680x4320 at 60Hz. I would say that most likely 144 Hz refresh is supported when the resolution is 2K (2560*1440) or lower, refer to https://www.intel.com/content/www/us/en/support/articles/000023004/graphics.html
Deivid A.
Hello deeepy,
Thanks for your time. I would like to know if the information provided was helpful for you. Please let me know if you have any further questions.
Deivid A.
Hello deeepy,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Hello deeepy,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
Thank you for the information.
It was helpful for me.
Thanks to all!
