23272 Discussions
Minecraft lag on HP Pavillion g6 Notebook PC.
RMana1
Hello First I'm sorry if the thread is not in the right forum but I need help.
I need help because I play Minecraft but I get like 15 FPS if in the world are big buildings I get like 5-7 FPS (In minimal settings)
My laptop specs are:
Intel(R) Pentium(R) CPU P6200 @ 2.13 GHz 2.13 GHz.
RAM 3.00 GB (2,86 GB usable)
Windows 7 Home Premium 64 bit Operating System.
Video Card:
Intel(R) HD Graphics (Pentium)
Total Available Graphics Memory 1274MB
Dedicated Video Memory 64MB
System Video Memory 0 MB
Shared System Memory 1210 MB
What is causing my laptop to lag on that game ? Is it because I use 64 bit OS on 3GB RAM than 32 bit OS?
Please help me because I want to play Minecraft normally.I don't plan buying a new laptop.
Kevin_M_Intel
Hello m0ns7err,
Thank you for sharing these details.
I would like to confirm more information about your system configuration so can you attach here your system information report?
How to get it?
System Information: Click Start> Type System Information> Click File> Export> Save File> Attach using Advanced Editor Options.
Besides this, do you know if the Game is running with latest patch?
I appreciate all information you can provide.
Kevin M
RMana1
This is the system configuration file.
Kevin_M_Intel
Hello m0ns7err,
What version of the game are you running?
Based on the latest game version (1.8), the graphics controller needed to run the game is a little higher than the one your computer is running.
Check for game updates if you have a old version of the game.
Kevin M
RMana1
I'm running on 1.8 but I get the same issue on 1.7.2,1.6.2..I'm using the mod Optifine to reduce the lag but when I play on bigger server (Mineplex,Hivemc etc.) I get 15 FPS with Optifine.I have 2 questions
First if I reinstall my windows to 32bit OS will it make a difference ?
Secoond is there any other way that I can use to make my FPS little bit more (like 30-35) that I don't get the lag?
Kevin_M_Intel
Hello m0ns7err,
Changing the Operating System to a 32 bit version should not make a different on game performance since this is related to System (hardware horsepower) performance.
I have checked this on a system similar to yours and I was not able to replicate this performance issue. Remember that when a processor has been designed for mobile platforms, it means the CPU processing power will be lower than a desktop platform due to the low voltage and power consumption design.
So I would say problem is with the system horsepower rather than the graphics controller.
I hope this helps you.
Kevin M
RMana1
Okay my last question is:
Is there anyway that I can use to improve my FPS little bit more just that I don;t get the lag?
vdaga1
im having the same issue.
when playing minecraft, GPU-Z reports 370~ mhz
when playing other games, GPU-Z shows my gpu ramps up to 770!
wish there was a fix.
Kevin_M_Intel
Hi m0ns7err,
I would say the only way is upgrading your system.
Hi Vasco,
Please stay with your other thread.
