23829 Discussions
Mobile Intel(R) 4 Series Express - Acceleration Not Available
I have a Dell Latitude E6400 running Win XP SP3, 4GB ram, with the Mobile Intel(R) 4 Series Express chipset. I am trying to run a flight simulator which requires some graphic acceleration. I've done the following:
1) Updated Mobile Intel(R) 4 Series Express drivers to 6.14.10.5420 using the Intel driver update feature.
2) I've run dxdiag and it shows the following - below:
3) I've installed the DirectX Control Panel and on the Direct3D tab I have Allow Hardware Acceleration checked.
Support folks for the flight simulator firm says the problem is that Display Memory shows N/A, and DDraw Status, D3D Status and APG Status show Not Available.
So how do I fix this so that acceleration is available?
Thank for any help you can provide.
System Information
Time of this report: 12/5/2012, 17:27:32
Machine name: DOUGLAPTOP
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.120504-1619)
Language: English (Regional Setting: English)
System Manufacturer: n/a
System Model: n/a
BIOS: n/a
Processor: Intel(R) Core(TM)2 Duo CPU P9600 @ 2.66GHz (2 CPUs)
Memory: 3536MB RAM
Page File: 940MB used, 4477MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Mobile Intel(R) 4 Series Express Chipset Family
Manufacturer: Intel Corporation
Chip type: Mobile Intel(R) 4 Series Express Chipset Family
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_2A42&SUBSYS_02331028&REV_07
Display Memory: n/a
Current Mode: 1440 x 900 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: igxprd32.dll
Driver Version: 6.14.0010.5420 (English)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 8/28/2012 18:34:36, 58368 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: igxpmp32.sys
Mini VDD Date: 8/28/2012 18:34:36, 2019200 bytes
Device Identifier: {D7B78E66-6902-11CF-B466-3922A6C2CB35}
Vendor ID: 0x8086
Device ID: 0x2A42
SubSys ID: 0x02331028
Revision ID: 0x0007
Revision ID: 0x0007
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Dr
DArce
Valued Contributor III
That kind of problem, has been well identified in the past and it is known to be related to the DirectX* setting and the operating system. For more information on how to troubleshoot this, you can refer to this site:
http://www.intel.com/support/graphics/sb/CS-003994.htm http://www.intel.com/support/graphics/sb/CS-003994.htm
Concerning the AGP acceleration you can check this article:
http://www.intel.com/support/graphics/sb/cs-009689.htm http://www.intel.com/support/graphics/sb/cs-009689.htm
DArce
Diego - thank you very much for your answer.
Following the first article did the trick and fixed my issue. I now have DirectX Acceleration available! Very much appreciated.
BTW, this problem may have been well identified within your circle, but a number of Google searches failed to bring it up for me. Also, the article that fixed the problem said it applied to Win 2000 - not XP. Also, on the list of products it applied to - it did not list the Intel 4 Series Express. But I am happy it worked, and I do appreciate your advice very much.
Doug
DArce
Hello Doug,
I am glad to hear that our assistance aided you in the resolution of the issue you were experiencing. If you run into any problems in the future or have any questions of a technical nature, please do not hesitate to contact us again.
And thank you for the feedback on the article, I will forward this to the appropriate team.
Happy holydays,
