We need your assistance to see what changed with every Intel graphics driver version after version 31.0.101.5333.
The reason why we are asking is because we have 25+ customers (out of several thousand) who are essentially not able to use different versions of our software due to a mouse lag issue appearing out of the blue. After gathering all kinds of machine specifications from these users this is the only common thread. They all have Intel graphics driver versions put out after version 31.0.101.5333.
So far, our customers have either had to disable their intel graphics cards altogether or hope they can find this old graphics driver online somewhere.
I would like to speak with someone or show you exactly how to reproduce this if possible because I am seeing online that many Autodesk users also had a similar issue.
Hi Jamesg89,
We appreciate that you brought this issue to our attention and for your keen observation that the problem happened after installing driver version later than 31.0.101.5333. We would work with you to further check this concern.
Please allow us to ask the following information, as we may need this to reproduce the issue:
1. If you can provide the following logs from one or two computers, it would really help us if we can get more information about any of the system. Please download and run our Intel® System Support Utility from this page, https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html. To run it, please press "Scan". After the scan is finished, click next and there will be a save button, giving you an option to save the logs to a text file, please do so and attach the file on your reply. You can refer to How to get the Intel® System Support Utility Logs on Windows* https://www.intel.com/content/www/us/en/support/articles/000057926/memory-and-storage.html for instructions.
2. Do the 25 systems have the same configuration (OS Build, components, driver versions, BIOS version, etc.)?
3. Kindly describe the application that your customers are using and where the mouse lagging is mostly experienced.
4. It seems that driver version 31.0.101.5333 is not found on our download center page. May we ask where did you obtain this driver? Is it through the manufacturer or was it installed together with a Windows update?
5. Aside from installing the driver, was either the Intel ARC Control Center, Intel Driver and Support Assistant, and Intel Graphics Command Center where installed on the machine?
6. If possible, kindly provide a video of the problem.
We will wait for your response.
Alfred S
Hi
Hello, Jamesg89.
Thank you for your detailed response and for providing the requested information. Please be informed that my colleague, Alfred is away, so I will be handling your inquiry in the meantime. Yes, I agree that having a discussion over a phone call would be advantageous to align on troubleshooting steps and explore potential solutions. Currently, we are unable to initiate a phone call for some reason, but please feel free to contact us via phone or initiate a ticket.
In line with the SSU logs, I'll be emailing you a request to provide the Intel SSU log file, as it includes confidential system specifications. Have you explored or tested any potential workarounds or interim solutions for affected customers? If you have done any steps to fix this issue before contacting us please give me those details so we don't repeat any unnecessary steps.
Von M.
Hi Von,
Hi Jamesg89,
Thank you for your response.
Given that the logs may contain sensitive information, we have sent an email to you to gather the logs and some other vital information.
We will wait for your reply.
Alfred S
Hi Jamesg89,
I wanted to check if you had the chance to read the email that we sent. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Alfred S
Hi Jamesg89,
Thank you providing those information.
Please allow us some time to check on this.
We will get back to you as soon as we have updates.
Alfred S
Hi Jamesg89,
Kindly check your inbox for our email.
Alfred S
Hi Jamesg89,
Alfred S
Hi Jamesg89,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers.
We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
