Hello there,
My laptop is RoG(GL503vd) intel HD 630
the problem is between disk usage 100% or GPU 100%
my laptop did freeze alot when i play games(total freeze= i can't even move my cursor for short time) or when i watch videos or open websites.
i fixed this problem by intel help around 1 or 2 years ago.But, i reinstalled my windows 1 week ago because it attacked by virus and then this freeze happened again.
i searched some solution and then i found the same solution that intel gave me 2 years ago(image below) but i can't download the drive anymore
can someone help me?
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
hello there,
this is the result
best regards, jason
- You have most outdated system - Windows and Drivers. In addition, looks that NIVIDIA Graphics adapter (which your laptop is equipped), is not enabled in BIOS.
- Start with checking in BIOS if the NVIDIA is enabled and if not, enable it.
- You have very old Windows version (1709). Download and use Microsoft Update Tool to upgrade your Windows to the latest version.
- This is page with drivers for your laptop.
- Start with NVIDIA Graphics Driver Version 24.21.13.9924. Download it and install.
- Download and install Asus Live Update and run it to check if there is more drivers to update.
Leon
