22827 Discussioni
NPU driver finishes OK but Error 1000 is reported
PhugoidEffect
Nuovo utente
46.674Visualizzazioni
Like described in the subject, the end of the installation is reported as successful, but Driver & Support Assistant lists as "Installation failed with error code 1000"
Tried twice, same outcome.
1 Soluzione
PhugoidEffect
Nuovo utente
12.611Visualizzazioni
None of these worked. It's pretty obvious it was just a status error, the driver was correctly installed on the first try, but the reporting software wasn't correctly signaled.
In any event, I just followed someone's suggestion to ignore that specific driver and it somewhat solved the issue.
Visualizza soluzione nel messaggio originale
67 Risposte
Frank90
Nuovo utente
7.795Visualizzazioni
Dietmar-Po
Nuovo collaboratore I
7.052Visualizzazioni
The Intel Driver Support Assistant repeatedly attempts to install version 4181 after every reboot, resulting in error 1000 and a persistent red dot icon in the Windows info bar.
Moi51
Nuovo utente
6.942Visualizzazioni
Bonjour,
J'ai aussi le même soucis.
J’espère que Intel va s'atteler à cela et y remédier rapidement.
J'ai hâte !
trongod
Principiante
5.927Visualizzazioni
Same issue as everyone else. On Legion Pro 7 16IAX10H - Type 83F5 running Windows 11 Pro 64-bit and Latest Intel Driver Support Assistant.
asafm
Principiante
5.921Visualizzazioni
Same for me.
  • MSI Prestige 14 AI Evo C1MG
  • Microsoft Windows 11 Home
  • Intel(R) Core(TM) Ultra 5 125H
RobertEnger
Nuovo utente
5.724Visualizzazioni
NPU driver 4181  installation fails on my machine too.
I have a 285k on Asus Proart Creator z890.
Windows 11  24H2  OS Build 26100.4652  up to date on all the MS supplied patches.
This is not an arcane, marginal OS.  For good or bad, it is a major, mainstream OS.
Intel Internal Testing should have detected whatever the problem is, BEFORE the update was sent out to customers.
bzoltick
Principiante
5.531Visualizzazioni
Hello everyone:
Intel's programmers need to fix the NPU driver issue.  I am running with an Ultra 7 265K CPU, ASRock Z890 motherboard, with all available Windows 11 updates.  The Ultra 7 265K CPU is a fine processor. I could not get the latest 32.0.100.4181 NPU driver to install properly,
Under Device Manager -> Neural Processors -> Intel AI Boost, the system detects the NPU. It shows the driver is installed. The Intel driver update app flags the driver with a yellow triangle.
I need to test it with the OpenVINO runtime.  I can confirm that I am getting the same "Installation failed with error code 1000" message.
vystora
Principiante
1.762Visualizzazioni
It seems the issue is linked to the latest NPU driver package. Even though Device Manager detects the Intel AI Boost, the installer may fail due to compatibility conflicts or leftover files. Try fully uninstalling the existing driver, then reinstalling using a clean driver package, or roll back to a stable release until Intel provides a fix.
2loki4u
Nuovo utente
1.753Visualizzazioni
Yeah, just a quick note on this post -
Do you think no one tried this already? Pretty clear at this point, if you read the thread as a whole, most of us tried this - it was/is a bug in their detection process. Then Intel decided to patch it to ignore the error - which didn't do anything but leave some people without the upgrade entirely -
Intel still refuses to explain and fully fix this - they just steam-rolled through it and released another update - which, seems (operative word) to have resolved the issue.
There is NOTHING the end user can do to fix this. Just to make it clear.
JS2025
Principiante
5.410Visualizzazioni
Same download problem for an Asus Zenbook S14 with 258V processor.
Sarahvp
Principiante
5.379Visualizzazioni
Same issue on a MSI motherboard. Seems to give many problems especially with MSI app player for me.
Roni4
Nuovo utente
5.359Visualizzazioni
Hey!
So, as mentioned in the title, downloaded the NPU driver, but I have the "error" after reboot. Tried twice, still error. I don't think that manual download will help, so I'll just ignore the update. ROG Zephyrus G16 (intel core ultra 9 185H).
I will wait for the update from mods, but I agree, QA Testers in Intel, You should've at least checked... I get that it's not an easy part, but... it's your job...
anyway, I hope that this will pass.
Orionn
Nuovo utente
5.283Visualizzazioni
Same problem since ... 3 days ago
They are not going to fix this ? Seriously?
Roni4
Nuovo utente
5.038Visualizzazioni
I just updated (yesterday), so it seems like there are really not paying attention here 🤷‍♀️
Orionn
Nuovo utente
4.989Visualizzazioni
do you mean you updated successfully yesterday ?
Roni4
Nuovo utente
4.962Visualizzazioni
No, I tried updating yesterday and I got the same error.
Amathus
Principiante
5.078Visualizzazioni
I am having the same issue with the NPU driver install. Has anyone come up with a solution? I have tried the direct download suggestion, but it did not work.
Roni4
Nuovo utente
5.039Visualizzazioni
Honestly, no. I just turned off the update app. If update wizard is saying that NPU is installed, that means it is installed. I guess that the support app has issues. Currently waiting for Intel mods to say smthing
AtTheSpeedLimit
Principiante
4.922Visualizzazioni
Same thing happened to me.
Even tried the option to clean install the new driver, still shows error 1000
Hopefully Intel will send out a notification acknowledging the error and fixes it
tommyr87
Principiante
4.913Visualizzazioni
Yep. I tried again this morning. Same error. Oh well. I am just waiting now...
roerisi
Principiante
4.884Visualizzazioni
My suggestion for now is to hide the update, until an update comes out that fixes the bug.
Rispondere
