22827 Discussions
NPU driver finishes OK but Error 1000 is reported
PhugoidEffect
Like described in the subject, the end of the installation is reported as successful, but Driver & Support Assistant lists as "Installation failed with error code 1000"
Tried twice, same outcome.
PhugoidEffect
None of these worked. It's pretty obvious it was just a status error, the driver was correctly installed on the first try, but the reporting software wasn't correctly signaled.
In any event, I just followed someone's suggestion to ignore that specific driver and it somewhat solved the issue.
Moi51
Bonjour,
Perso j'ai tout passé en revue et je n'ai jamais pu installer cette mise à jour, toujours message d'erreur 1000.
Maintenant cette mise à jour ne m'est même pu proposée.
Que faut il faire pour que intel me propose à nouveau des mises à jour ?
Merci
Anubis
hi together,
many replies are to MSI Boards,
I did a Bios-update and NPU driver got installed without error 1000
greetings
JedG_Intel
Hello PhugoidEffect,
Jed G.
ayla74108
Hey PhugoidEffect,
That error code 1000 can be pretty frustrating! Sometimes it helps to run the installer as an administrator or temporarily disable antivirus software during the installation. Have you tried those steps? Also, make sure your Windows updates are fully installed.
If that doesn’t work, maybe try downloading the latest version of the Driver & Support Assistant from Intel’s official site again. Hope you get it sorted soon!
PhugoidEffect
