Hallo Intel Teams,
I want to report, Necrovision v1.2 DX10 crashes on my i7-3770 HD 4000 GFX.
Sometimes i can play 3 to 5 minutes... somtimes it crash by loading the Map.
Windows Log, show, (Error in Moduls: igd10umd32.dll, Version: 9.17.10.2792).
I testetd only with the driver version 2792. I dont want install previews driver, becuse Driver v2792 is the best for my HD 4000
If i Start Necrovision DX9, the game work very nice with no crash.
I hop Intel can fix it.
My system,
Asus P8Z68-V/GEN3
Intel i7-3770
2x8GB 1600MHz
SB Recon3D
2x500GB HDD Intel Raid0 + 60GB SSD on Intel IRST Accelerate
Windows 7 Ultimate x64
- Tags:
- Intel® HD Graphics
I noticed you have the version 2792 graphics driver, and that it work best for your HD4000, but I do recommend getting the latest graphics driver from the link below:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21430&ProdId=3498&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21430&ProdId=3498&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=Drivers
I also recommend the game troubleshooting steps at the link below:
http://www.intel.com/support/graphics/sb/cs-010486.htm http://www.intel.com/support/graphics/sb/cs-010486.htm
Michael
Hallo Michael_intel,
I installed the driver version 2761 from your link, but the Necrovision DX10 crashes on this driver to.
this time windows show error with d3d10core.dll.
Here is the Windos error Log in German Language...
[code]
Name der fehlerhaften Anwendung: NecroVisioN.exe, Version: 0.0.0.0, Zeitstempel: 0x4a098b28
Name des fehlerhaften Moduls: d3d10core.dll, Version: 6.1.7600.16385, Zeitstempel: 0x4a5bd9a3
Ausnahmecode: 0xc0000005
Fehleroffset: 0x00024830
ID des fehlerhaften Prozesses: 0x54c
Startzeit der fehlerhaften Anwendung: 0x01cd7a6d52cf8804
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\1C Publishing EU\NecroVisioN\Bin\NecroVisioN.exe
Pfad des fehlerhaften Moduls: C:\Windows\system32\d3d10core.dll
Berichtskennung: e6f0134a-e660-11e1-b95e-005056c00008
[/code]
d3d10core dll is a DirectX runtime dll, not part of the Intel graphics driver. Without more data, I would guess that this is an application bug (e.g. not checking a return code for a createshader or createresource call and then blindly using the (still NULL) out parameter pointer in a later API call. Whoever is debugging this may want to do a PIX capture or run with the DirectX SDK "debug" layer on to see if there are any fail return codes.
why with driver v2792 it show error in igd10umd32.dll ?
I think intel need only optimize the HD Graphics driver for this game.
