22963 Discussions
No 4k@60Hz output with new Xe Graphics (i7-1165G7)
w_usher
Hi all, I just picked up the XPS 13 9310, and am having one small issue. I've got an LG 27UK850-W 27" 4K monitor that I want to use it with, however I can't seem to drive the monitor at 4k@60Hz. This is with both the latest 27.20.100.8783 driver and the older one Dell installs ( 27.20.100.8681). It's not an issue with the monitor (the same setup works fine with my Mac over TB3), so it seems to be something with the laptop GPU drivers. It can drive at at 60Hz at lower resolutions, but not 4K. When looking into the supported modes of the monitor, 3840x2160 @ 60Hz is there (monitor.png) but can't be selected (no available.png)
Maria_R_Intel
Hello w_usher,
We noticed that you have contacted Intel® Customer Support directly regarding the same issue here described and we found out that you have an internal support case open. In this case, we will proceed to close this thread to avoid duplication of effort and the support will continue through the internal case.
Maria R.
