23282 Discussions
No Hdmi signal from Hp laptop omen to Samsung qled 54
Regi
Hi i have an omen laptop w00017 series and i cant connect it to my samsung qled tv
Windows 10 appears samsung as generic pnp monitor and in graphic driver i had intel 530 as long with gtx nvidia. When i roll back intel driver to generic hd intel and connect laptop with samsung tv it doesn't support 3840 in screen and goes black. When i change that to 1920 x 1080 it shows in tv but it flickers and it keeps disconnecting and connecting
I did fresh setup of the windows i try everything i changed 10 cables it seems that is a driver issue
Please help
Regi
Updated it was a faulty cable after all thank you
MUC
Honored Contributor I
This is a platform with Intel Core i7-6700HQ (Skylake). The HDMI port on the right side of this laptop is internally connected to the Nvidia GTX. Please install the HP graphics driver:
https://support.hp.com/us-en/drivers/omen-by-hp-17-w000-laptop-pc-series/10862328
The HDMI port corresponds to version 2.0, which means you can output a maximum of 4K @ 60 Hz. To do this, please connect a "Premium High Speed HDMI Cable" to the TV and activate the Input Signal Plus option within the TV settings:
Regi
Thank you very much i install this driver and intel driver from the link you provide and in 1980x1920 i have image in tv but it have snows its not so clear. Also if i change in 4k settings in samsung it doesn't show any image to samsung only in 1980 x 1920 i activate inout signal plus to tv and it helped but no picture in 4k my hdmi cable is 2.0
Thank you
Regi
