23081 Discussions
Non riesco a trovare i driver aggiornati per la mia scheda video intel come si fa? id hardware PCI\VEN_8086&DEV_2E12&SUBSYS_3034103C&REV_03
Qualcuno mi puo aiutare non riesco a trovare i driver aggiornati della mia scheda video non so nenache come si chiama, vi mostro il mio id hardware : id hardware PCI\VEN_8086&DEV_2E12&SUBSYS_3034103C&REV_03
Stefan3D
Ma sono vecchi voglio queli più recenti ho Windows 10 pro
Stefan3D
According to https://www.intel.com/content/www/us/en/support/graphics-drivers/000005526.html Supported Operating Systems for Intel® Graphics Products Intel doesnt support your legacy GPU under Windows 10.
Only option is to grab the driver 8.15.10.2702 from Microsoft
http://download.windowsupdate.com/msdownload/update/driver/drvs/2013/04/200000265_b70e6e89dc0f24433f6fcc6b33d5f160f30a33cd.cab http://download.windowsupdate.com/msdownload/update/driver/drvs/2013/04/200000265_b70e6e89dc0f24433f6fcc6b33d5f160f30a33
Install this driver build via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
Treat CAB ike ZIP
niente non riesco a trovare driver aggiornati almeno del 2017 quando vado su gestione periferiche e faccio l'opperazione manuale ricevo il seguente messaggio " windows ha stabilito che il driver ottimale per questo dispositivo e già installato " Ma sono fuori produzione questi driver?
Hello Tequiero1979,
After translating your message I understand you are trying to install graphics driver in your computer.
Let me apologize for any inconvenience this issue may be causing to you.
In order to help you better I would like to gather more information about the configuration you have in the computer. Please attach to this thread the .txt file the Intel® System Support Utility will generate https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
To attach a file, you must click "Use Advanced Editor" on the upper right hand corner of the response box, then the "attach" option will appear on the bottom right hand corner of the response box.
Fred D.
Non ho capito niente di quello che devo fare cerca di essere più preciso grazie
# SSU Scan Information
Scan Info:
Version:"2.5.0.8"
Date:"08/05/2017"
Time:"00:01:09.8393742"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"Hewlett-Packard"
BIOS Mode:"Legacy"
BIOS Version/Date:"Hewlett-Packard 786G1 v01.26 , 12/07/2011 12:00"
CD or DVD:"HL-DT-ST DVDRAM GH24NSB0"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz , GenuineIntel"
Secure Boot State:"Not Available"
SMBIOS Version:"2.5"
Sound Card:"ManyCam Virtual Microphone"
Sound Card:"USB Speakers"
Sound Card:"Dispositivo High Definition Audio"
System Manufacturer:"Hewlett-Packard"
System Model:"HP Compaq dc7900 Small Form Factor"
System SKU:"KP721AV"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"1,73 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Q45/Q43 Express Chipset (Microsoft Corporation - WDDM 1.1)"
Link:" http://www.intel.com/content/www/us/en/search.html?keyword=Q45/Q43+Express+Chipset+(Microsoft+Corporation+++WDDM+1.1)"
CoInstallers:"oem3.inf,iEGL0,Internal,Intel(R) 4 Series Express Chipset Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmd64.sys"
Driver Date:"03/11/2013 01:00"
Driver Path:"C:\Windows\system32\DRIVERS\igdkmd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"8.15.10.2702"
INF:"oem3.inf"
INF Section:"iEGL0"
Install Date:"Not Available"
Installed Drivers:"igdumd64.dll,igd10umd64.dll,igdumd32,igd10umd32"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_2E12&SUBSYS_3034103C&REV_03\3&B1BFB68&0&10"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"60 Hz"
Refresh Rate - Minimum:"59 Hz"
Resolution:"1360 X 768"
Scan Mode:"Noninterlaced"
Service Name:"igfx"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) 4 Series Express Chipset Family"
Adapter DAC Type:"Not Available"
Adapter RAM:"Not Available"
Bits Per Pixel:"32"
CoInstallers:"oem3.inf,iEGL1,Not Available,Not Available"
INF:"oem3.inf"
INF Section:"iEGL1"
Monochrome:"No"
Hello Tequiero1979,
I just sent a private message to you. Please check your inbox.
Fred D.
