I have the Nuc 5i5RYH. It's running in Windows 11 Pro. I have the following driver errors. I installed the downloader app and it didn't fix the problem. It didn't do anything at all actually. Internet and everything seems to be working fine on the pc. I just don't like having driver issues appear in the device manager. Can you tell me how I can fix these issues?
You need to install the NUC-specific Intel Device Software package. It should resolve most of these. For a NUC this old, you aren't going to find the package on the Intel site (they don't provide downloads for discontinued products). I have attached the version I have in my archive.
Hope this helps,
Thanks for the driver. Strangely, it solved three of the driver issues but didn't fixed the other two.
Then I installed the Lan_Win8,164_20.1 driver from my archive hoping to fix those two remaining issues but got the following error message instead.
I'm not really sure what drive it's talking about. It's a nuc. So maybe it's the wrong driver?
No I'm on Win11. I was just hoping it would resolve it but obviously it didn't. So any other ideas how I can address those two remaining issues?
What about Wireless and Bluetooth, do you have a module installed?
Because Intel does not provide download support for discontinued Wireless adapters any longer, I created a share where I make available the final driver packages that included support for most of these adapters. Use this link: https://1drv.ms/f/s!AtacZBU04mo-j-tQ34BdSDv6y1BFsg?e=7gn50T to access this share. Subfolders provide final driver packages for most of the Discontinued Wireless adapters.
Yes I actually have the Wireless and Bluetooth original files in my drive. They are installed and are fine. But the two issues still remain.
Have you installed the RealTek Audio driver package? The package that I have in my archive (AUD_Win10_64_6.0.8854.1_RY.zip) is available in my Other Legacy Drivers share.
If that doesn't fix it, I am at a loss. Open the entries in Device Manager, select the Details tab and then Property Hardware_Ids. Please respond with the shortest of the listed PCI identifiers (it will look like "PCI\VEN_####&DEV_###&CC_####").
I didn't because I have the original drivers in my drive already. Also, after I set everything up, it turns out that this nuc is way too slow for what I am doing. So I am going to use my nuc 8 series instead which is already assigned for something else. But I have no choice now. Thank you so much for your help. I really appreciate it!
