Community
cancel
Showing results for
Search instead for
Did you mean:
JFerr64
O assistente de Drivers da Intel atualiza o driver de vídeo e instala a versão 15.10. Após a atualização apresenta falha de funcionamento e o vídeo trava e exibe a mensagem "não foi possível acessar o hardware gráfico" para todos os aplicativos.
Devo voltar para a versão anterior do driver e bloquear a atualização?
Windows 10 64 bits
Video Processor   Intel® HD Graphics Family
Resolution   1360 x 768
Bits Per Pixel   32
Number of Colors   4294967296
Refresh Rate - Current   60 Hz
Refresh Rate - Maximum   75 Hz
Refresh Rate - Minimum   59 Hz
Driver Provider   Intel Corporation
Driver Version   20.19.15.5107
Driver Date   15/11/2019
Adapter DAC Type   Internal
Adapter RAM   1,00 GB
Availability   Running at full power
Status   This device is working properly.
Location   PCI bus 0, device 2, function 0
Device Id   PCI\VEN_8086&DEV_0402&SUBSYS_85341043&REV_06\3&11583659&0&10
AlHill
What processor model number?
What version of Windows 10? 1909?
What is the model number of your laptop or system/motherboard?
Do you have dual graphics?
Doc
JFerr64
Hi Al.Hill,
A placa mãe é ASUS
System Manufacturer   ASUS
System Model   All Series
System Type   Desktop
Motherboard Manufacturer   ASUSTeK COMPUTER INC.
Motherboard Product   H81M-C/BR
Version   Rev X.0x
BIOS Version   2004
Date   27/10/2014
SMBIOS Version   2.7
Secure Boot   Off
Processador:
Intel® Pentium® CPU G3220 @ 3.00GHz
Manufacturer   GenuineIntel
Description   Intel64 Family 6 Model 60 Stepping 3
Architecture   x64
# of Cores   2
# of Threads   2
Processor Base Frequency   3000 MHz
Current Voltage   1.8
Level 2 Cache   512 Kb
Level 3 Cache   3072 Kb
Processor Id   0x306C3
Revision   15363
Windows 10 64 bits V1909
AlHill
Use the vga driver here for Windows 10:
https://www.asus.com/supportonly/H81M-CBR/HelpDesk_Download/
Do not use IDSA on your motherboard.
Doc
JFerr64
Ok, thanks Al.Hill
