Hi guys,
i bought new NUC DC3217IYE last week. I have latest BIOS ver.:0042 and latest HD4000 graphic driver.
I have problem with overscan (my TV doesnt have 1:1 mapping, only 16:9 with overscan.).
My old PC with ATI Radeon have in driver menu overscan correction option, after apllying it, screen was sharp and clear!! like 1:1 mapping.
But with NUC it doesnt works! I can see horizontal and vertical sliders, if I correct it with this, size is OK, but screen is blurry, like interpolated, text is fuzzy and hard to read. I tryed every combination of H/V sliders (from 80-100%) without success = still blurry image.
Is thery any option which could help me?
Thanks for any help!
nobody?
so, ATI graphic has overscan correction which doesnt affect sharpness, its like 1:1.
and Intel doesnt have it...only interpolated crap.. 😞
i am disappointed about intel graphic
Hi prachart,
What display are you using (exact model # please!). Also, what resolution are you trying to set it to?
-Nic
it doesnt matter what type of display I am using .. important is that I need functional overscan correction, without degrading srceen parametrs, like ATI Radeon have!
I tryed connect new TV, which have "Just Scan" (1:1 maping) function, but there is another problem!!!
I have satellite receiver, blue-ray player and NUC htpc connected through YAMAHA receiver (with HDMI 1.4a) with Samsung TV.
So If I switch HDMI input on receiver, for example to blueray player, TV redetect HDMI input and set "16:9" mode (with overscan) again. Then I switch to NUC and I need set again "Just scan" mode. ITS SOOOO ENOING !!!!! grrrr
On old HTPC with ATI Radeon, I have to just set overscan correction and everythink was OK, screen was sharp like needle!
I have one idea yet! I will try remove 19 pin (hot-plug) in HDMI cable which connected receiver and TV.
I hope it cause that TV doesnt notice that HDMI input device was changed so there isnt any redetection and "Just Scan" doesnt switch back to "16:9" mode
It sounds like you have an AV/R device between your system and your display. This could be causing your problem. Can you post a copy of your Intel® Graphics Driver Report please? Here is a document on how to provide that information; http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
-Nic
Yes, I have AV receiver YAMAHA, but it doesnt cause this problem!
I tryed connect NUC directly to the TV.
Problem is HD4000 in NUC (DC3217IYE) which can´t correct (H/V slieders) overscan without degrading final screen, its interpolated!
ATI Radeon in old Lenovo Q180 fix overscan (in Catalyst Control Center) without any problem! everythink was sharp, like 1:1 mapping.
Why NUC (HD4000) doesnt support this ?
Hi prachart,
Can you provide the Intel® Graphics Driver Report as detailed in the link of my previous post? Also, to clarify - the issue you're having is that regardless of whether you use the YAMAHA* receiver or a straight-through connection, your screen is blurry due to your display not having 1:1 mapping with your resolution? Are you running in the native display resolution for your TV? What model is your Samsung* TV?
-Nic
The problem was resolved. I had to set name on HDMI2 to "PC" and then TV stay in "16:9" mode, but it behave like "Just Scan", so everythink is OK. Problem were in TV, not in NUC, I am sorry INTEL.
