23077 Discussions
OpenGL 4.5 and Intel HD Graphics Family
Arnaud2
Is there any update to my graphic chipset that would also update OpenGL to a 4.5 version?
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Arnaud2
Thanks AlHill
So there's the complete config scan as attachement.
Hope it will help
Stefan3D
PNP Device ID:"PCI\VEN_8086&DEV_0A16
That is a Haswell GPU.
You can update driver to 5171, but it still only supports OpenGL 4.4
Which particular application requires OpenGL 4.5?
Arnaud2
That'd be for some games and android emulator that need opengl es 3.1
the compatibility for that would be opengl 4.5
