23257 Discussions
OpenGL support for Mobile Intel 4 Series Express Chipset Family
aasda2
Hi, I have Mobile Intel 4 Series Express Chipset Family and one of my games (Starwars : Knight of the Old Republic) needs me to set specific options for OpenGL. On "http://www.lucasforums.com/showthread.php?t=148276 http://www.lucasforums.com/showthread.php?t=148276", it asks me to "Select Blit as the Flipping Policy". This solution, however, isn't there in the only compatible versions of the drivers (and the panel that comes with it) for Win7. It was possible on XP, but not on Win7. When I try to install the drivers in compatibility mode, it fails (I felt supid, but I had to try at least). From what I understand, Microsoft and Intel did not release any drivers for this chipset that allows you to change this particular OpenGL option.
I searched for quite a while on a lot of different forums for gaming, on lucasarts, intel, microsoft, and I didn't find a solution that worked. Can anyone help me with that ? Thanks.
Silvia_L_Intel1
Hello Farpain, I would need to tell you that this is going to be expected as the graphic engine is not the same on Windows 7 as it used to be on Windows XP.
You may want to check with the game developer if there is a patch available that you can use.
