23266 Discussions
Overclocking Intel HD 4600 iGPU over 1350 MHz resets XTU
HLeon5
Hello!
Recently i started overclocking my CPU with XTU, Then later i gave the integrated graphics overclocking a shot, all is good until you go past 1350 MHz, then the screen flashes for a second and XTU resets to 1150 MHz. (BTW I'm on a laptop.)
Help?
INTEL HD 4600
GT 740M
I7 4700MQ
Hello GammaFive,
Thank you for joining the Graphics community.
I just wanted to let you know that Intel does not provide assistance for overclocking, so in this case the best thing is to wait for another community member to post similar experience or get more feedback on other forums. Maybe you could try with http://www.overclockers.com/forums/ Overclockers Forums or http://forums.extremeoverclocking.com/ EXTREME Overclocking Forums - Learn To Overclock Your PC Hardware.
Before visiting these sites, please bear in mind that altering PC clock or memory frequency and /or voltage may reduce system stability and use life of the system, memory and processor; it causes the processor and other system components to fail; it causes reductions in system performance; it causes additional heat and other damage; and affects system data integrity. Intel assumes no responsibility that the memory, included if used with altered clock frequencies and / or voltages, will be fit for any particular purpose.
The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy C.
