22989 Discussions
P67/H67 Chipset Fault - related to random crashes in Win7??
Dear Intel/Community,
Being an early-adopter of the new 2600K Sandybridge + P67 chipset cinannigans, I was suprised to see how unstable the system is under Win7 (64bit). Works OK most of the time, but once in the OS, random crashes (mixture of apps unresponding, full-on freezes, BSODs and even self-restarts) occur at random times, overclocked or not, idle or busy. So something is very unstable.
I thought it was just the way I set it up with something or other causing conflicts, but after fiddling and testing and updating drivers/BIOS versions for days I have had no joy in curing the problem. Also, by googling "P67 random freezes/crashes" it became apparent to me that a huge number of other users are experiencing the exact same problem, even on completely different motherboards & setups.
I have a Gigabyte P67 UD5 mobo, and my OS hard drives aren't connected to the acclaimed faulty SATA2 ports (using dual WD Raptors on RAID 0 on the SATA3 ports), only a media drive (rarely accessed) and DVD drive (rarely used) are connected to the SATA2 ports, so could there be something else wrong with the chipset other than the bio-degradable SATA2 controller? Intel, have you kept something quiet?
Anyone else experiencing these problems? Maybe Windows 7 badly needs a service pack?
Mark
RIG:
OS: Win 7 64bit
CPU: i7 2600K Sandybridge with H70 hydro cooler (runs at 20-40C most of the time).
MOBO: Gigabyte P67 UD5
MEM: DDR3 1866Mhz Corsair 8GB (4GB x 2)
GFX: 2 x MSI Geforce 460 GTX 1GB SLI'ed
SOUND: Xonar D2X PCI-E
HDDs: Dual WD Velociraptor 600GBs on RAID 0 SATAIII on SATA3 ports, old WD Caviar 250GB SATA1 on SATA2 port
OPTICAL: Bog Standard (but brand new) Samsung DVD-RW on SATA2 port.
Maybe it's too late to help but if your reboot problems continue, I resolved mine with set RAM frequency to 1066 even if original frequency is 1600.
I have no more reboot.
You know what, you are bang-on. Shortly after I posted that message I realised it was the DDR that was not set to "Extreme Memory Profile" and I had it manually set to 1866Mhz. I noticed by doing this it changed some of the voltages and timings automatically, and it hasn't crashed since!
Apologies to Intel for doubting them.....
DSilv11
Valued Contributor III
To err is human, but to really foul things up requires a computer. ~Farmer's Almanac, 1978
