23821 Discussions
Persistent BSOD - High Probability on RDP Connect to Idle/Locked PC
Patrick_Star_Y
Hello Intel Community and Support Team,
I am writing to report a persistent and long-standing Blue Screen of Death (BSOD) issue I've experienced with Intel Arc graphics drivers. This issue dates back to the launch of the Arc A770 and continues to occur on my current system featuring the recently released Arc B580.
System Configuration:
  • CPU: AMD Ryzen 9 7950X (iGPU Disabled in BIOS)
  • GPU: Maxsun Intel Arc B580 12G (Triple Fan version) - (Previously experienced the same issue on an Intel Arc A770 16GB Limited Edition)
  • Motherboard: Gigabyte B650M AORUS PRO AX
  • RAM: KingBank DDR5 Hynix A-die 128GB (4x32GB) @ 5200MT/s
  • OS: Windows 11 Pro 26100.3624
  • Intel Graphics Driver Version: 32.0.101.6653, download  from Intel's site
Bug Description:
The system experiences a BSOD with the Bug Check Code 0x00000050 (PAGE_FAULT_IN_NONPAGED_AREA). The crash dump analysis consistently points to the Intel Graphics Kernel Mode Driver, igdkmdnd64.sys, as the faulting module.
  • Bug Check Code: 0x50
  • Bug Check String: PAGE_FAULT_IN_NONPAGED_AREA
  • Faulting Module: igdkmdnd64.sys
  • Arguments from recent dump (040625-9125-01.dmp):
    • Arg1: ffffd3f20e1ff800 (Memory referenced)
    • Arg2: 0000000000000002 (Write operation)
    • Arg3: fffff8006e8b6206 (Instruction address in igdkmdnd64.sys)
    • Arg4: 0000000000000002
  • Process Context: The crash often occurs within the context of dwm.exe.
Steps to Reproduce:
The BSOD occurs with a high probability under the following specific conditions:
  1. Leave the computer idle until it enters a standby/idle state, the screen is locked, and the monitor(s) have entered sleep mode (black screen).
  2. From another computer, attempt to connect to this machine using Windows Remote Desktop Connection (RDP).
  3. A BSOD occurs with high likelihood, either immediately upon the connection attempt or shortly after the remote session tries to initialize.
Impact and Context:
This system is used in a productivity environment, and this recurring BSOD has a severe negative impact on my work.
Importantly, this system was previously perfectly stable with both an NVIDIA GeForce RTX 4070 Super and an AMD Radeon RX 7700 XT installed, experiencing no similar RDP-related crashes. The problem only started after installing the Arc B580.
Furthermore, this is not a new issue isolated to the B580. I experienced the exact same bug (same code, module, RDP trigger) with an Intel Arc A770 16GB Limited Edition on a previous system, dating back approximately 2.5 years to the card's launch timeframe. This strongly indicates a persistent, underlying driver issue across Arc generations in handling RDP connections or related system state transitions.
Troubleshooting Attempted:
  • Before installing the Arc B580 and its drivers, I performed a thorough driver removal using DDU in Safe Mode to eliminate potential conflicts.
  • I then installed the latest official Arc graphics driver downloaded directly from the Intel website.
  • Despite these steps, the BSOD issue persists on the B580, replicating the behavior seen on the A770 years ago.
  • Ensured Windows, Motherboard BIOS, and AMD Chipset drivers are all up-to-date.
  • Verified system stability otherwise (passes stress tests, memory checks, etc.).
Request:
Could the Intel graphics driver team please prioritize investigating this critical, long-standing issue? The inability to reliably use Remote Desktop severely hinders the usability of Arc GPUs in professional and productivity scenarios. I have attached the most recent minidump file (040625-9125-01.dmp) to this post [Or: I can provide the minidump file upon request].
Thank you for your time and assistance.
Patrick_Star_Y
************* Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
   NonInteractiveNuget : true
   AllowNugetMSCredentialProviderInstall : true
   AllowParallelInitializationOfLocalRepositories : true
   EnableRedirectToChakraJsProvider : false
   -- Configuring repositories
      ----> Repository : LocalInstalled, Enabled: true
      ----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.015 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.188 seconds
   ----> Repository : UserExtensions, Enabled: true, Packages count: 0
   ----> Repository : LocalInstalled, Enabled: true, Packages count: 43
Microsoft (R) Windows Debugger Version 10.0.27793.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\040625-9125-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 26100 MP (32 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Kernel base = 0xfffff800`97a00000 PsLoadedModuleList = 0xfffff800`988f47a0
Debug session time: Sun Apr  6 01:50:31.102 2025 (UTC + 8:00)
System Uptime: 4 days 11:42:54.465
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000b9`19923018).  Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -vnt!KeBugCheckEx:
fffff800`97eb7ce0 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:fffffc0b`4be0d7f0=0000000000000050
12: kd> !analyze -v
*                        Bugcheck Analysis                                    *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced.  This cannot be protected by try-except.
Typically the address is just plain bad or it is pointing at freed memory.
Arguments:
Arg1: ffffd3f20e1ff800, memory referenced.
Arg2: 0000000000000002, X64: bit 0 set if the fault was due to a not-present PTE.
	bit 1 is set if the fault was due to a write, clear if a read.
	bit 3 is set if the processor decided the fault was due to a corrupted PTE.
	bit 4 is set if the fault was due to attempted execute of a no-execute PTE.
	- ARM64: bit 1 is set if the fault was due to a write, clear if a read.
	bit 3 is set if the fault was due to attempted execute of a no-execute PTE.
Arg3: fffff8006e8b6206, If non-zero, the instruction address which referenced the bad memory
	address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
*** WARNING: Unable to verify timestamp for igdkmdnd64.sys
KEY_VALUES_STRING: 1
    Key  : AV.Type
    Value: Write
    Key  : Analysis.CPU.mSec
    Value: 1359
    Key  : Analysis.Elapsed.mSec
    Value: 1462
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 265
    Key  : Analysis.Init.Elapsed.mSec
    Value: 9813
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 89
    Key  : Analysis.Version.DbgEng
    Value: 10.0.27793.1000
    Key  : Analysis.Version.Description
    Value: 10.2410.02.02 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2410.2.2
    Key  : Bugcheck.Code.LegacyAPI
    Value: 0x50
    Key  : Bugcheck.Code.TargetModel
    Value: 0x50
    Key  : Dump.Attributes.AsUlong
    Value: 0x21008
    Key  : Dump.Attributes.DiagDataWrittenToHeader
    Value: 1
    Key  : Dump.Attributes.ErrorCode
    Value: 0x0
    Key  : Dump.Attributes.KernelGeneratedTriageDump
    Value: 1
    Key  : Dump.Attributes.LastLine
    Value: Dump completed successfully.
    Key  : Dump.Attributes.ProgressPercentage
    Value: 0
    Key  : Failure.Bucket
    Value: AV_W_(null)_igdkmdnd64!unknown_function
    Key  : Failure.Exception.IP.Address
    Value: 0xfffff8006e8b6206
    Key  : Failure.Exception.IP.Module
    Value: igdkmdnd64
    Key  : Failure.Exception.IP.Offset
    Value: 0x306206
    Key  : Failure.Hash
    Value: {edb96eb7-b673-d178-0b8a-baf22f5912b8}
BUGCHECK_CODE:  50
BUGCHECK_P1: ffffd3f20e1ff800
BUGCHECK_P2: 2
BUGCHECK_P3: fffff8006e8b6206
BUGCHECK_P4: 2
FILE_IN_CAB:  040625-9125-01.dmp
DUMP_FILE_ATTRIBUTES: 0x21008
  Kernel Generated Triage Dump
FAULTING_THREAD:  ffffab065fbbf040
READ_ADDRESS: fffff800989c34b0: Unable to get MiVisibleState
Unable to get NonPagedPoolStart
Unable to get NonPagedPoolEnd
Unable to get PagedPoolStart
Unable to get PagedPoolEnd
unable to get nt!MmSpecialPagesInUse
 ffffd3f20e1ff800
MM_INTERNAL_CODE:  2
IMAGE_NAME:  igdkmdnd64.sys
MODULE_NAME: igdkmdnd64
FAULTING_MODULE: fffff8006e5b0000 igdkmdnd64
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  dwm.exe
TRAP_FRAME:  fffffc0b4be0da50 -- (.trap 0xfffffc0b4be0da50)NOTE: The trap frame does not contain all registers.Some register values may be zeroed or incorrect.rax=000000006e706b37 rbx=0000000000000000 rcx=ffffab0632c02000
rdx=fffffc0b4be0dce0 rsi=0000000000000000 rdi=0000000000000000
rip=fffff8006e8b6206 rsp=fffffc0b4be0dbe0 rbp=fffffc0b4be0dce0
 r8=0000000000000004  r9=00000000fffff800 r10=ffffd3f20e1ff800
r11=fffffc0b4be0dd18 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei pl zr na po nc
igdkmdnd64+0x306206:
fffff800`6e8b6206 418902          mov     dword ptr [r10],eax ds:ffffd3f2`0e1ff800=????????
Resetting default scope
STACK_TEXT:
fffffc0b`4be0d7e8 fffff800`97cc9301     : 00000000`00000050 ffffd3f2`0e1ff800 00000000`00000002 fffffc0b`4be0da50 : nt!KeBugCheckEx
fffffc0b`4be0d7f0 fffff800`97c8ebdf     : ffffd3f2`0e1ff800 00000000`00001000 00000000`00000002 fffff800`97a00000 : nt!MiSystemFault+0x735
fffffc0b`4be0d8e0 fffff800`980880cb     : 00000000`00000000 00000000`00000000 00000000`00000000 fffffc0b`4be0dc60 : nt!MmAccessFault+0x2ff
fffffc0b`4be0da50 fffff800`6e8b6206     : ffffab06`32c02000 fffff800`6e8b610c fffffc0b`4be0dc00 00000000`00000000 : nt!KiPageFault+0x38b
fffffc0b`4be0dbe0 ffffab06`32c02000     : fffff800`6e8b610c fffffc0b`4be0dc00 00000000`00000000 00000000`fffff800 : igdkmdnd64+0x306206
fffffc0b`4be0dbe8 fffff800`6e8b610c     : fffffc0b`4be0dc00 00000000`00000000 00000000`fffff800 00000000`00000000 : 0xffffab06`32c02000
fffffc0b`4be0dbf0 fffffc0b`4be0dc00     : 00000000`00000000 00000000`fffff800 00000000`00000000 00000000`00000005 : igdkmdnd64+0x30610c
fffffc0b`4be0dbf8 00000000`00000000     : 00000000`fffff800 00000000`00000000 00000000`00000005 fffffc0b`4be0dc60 : 0xfffffc0b`4be0dc00
SYMBOL_NAME:  igdkmdnd64+306206
STACK_COMMAND:  .process /r /p 0xffffab06ca8e90c0; .thread 0xffffab065fbbf040 ; kb
BUCKET_ID_FUNC_OFFSET:  306206
FAILURE_BUCKET_ID:  AV_W_(null)_igdkmdnd64!unknown_function
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {edb96eb7-b673-d178-0b8a-baf22f5912b8}
Followup:     MachineOwner
RandyT_Intel
Hello @Patrick_Star_Y ,
Let me look into this concern for you. I will coordinate this matter internally and provide you with an update as soon as there is progress or development. I appreciate your patience and the detailed description of the issue.
Randy T.
Patrick_Star_Y
Do you need the minidump file from the BSOD? If so, how should I send it to you?
RandyT_Intel
Yes, please. It would be helpful to include the crash report. Additionally, could you try updating to the latest version of the graphics driver, 32.0.101.6732, and observe if the issue persists? You might also consider updating the motherboard BIOS or loading the default settings in the BIOS configuration. Let me know if there are any changes.
Randy T.
Patrick_Star_Y
This is the dump file from when the BSOD occurred.
RandyT_Intel
Following our previous discussion, you may also check the available resolutions provided here, as this might help resolve the issue and determine the reason behind the error code. Let me know if this helps.
Bug Check 0x50 PAGE_FAULT_IN_NONPAGED_AREA - Windows drivers | Microsoft Learn
Randy T.
RandyT_Intel
Randy T.
Patrick_Star_Y
Apologies for the delayed response; I've been quite busy with work recently. Thank you for your previous messages and suggestions.
Since my initial report (where I was using driver 32.0.101.6653), I have had the chance to test two different WHQL driver versions based on your feedback and subsequent releases:
  1. Driver Version 32.0.101.6651: Unfortunately, with this driver, I still experienced driver crashes. However, the symptom changed: instead of a Blue Screen of Death (BSOD), the driver would simply crash without bringing down the system. This still consistently occurred after the PC (with the Arc B580 12G) was accessed via Windows 11 Remote Desktop (RDP) and then left idle for several hours. When the crash happened, the Intel® Graphics Software (Arc Control) would display a notification indicating a driver problem, but no BSOD occurred.
  2. Hypothesis & Latest Test (Driver Version 32.0.101.6734): The behavior with driver .6651 led me to suspect that perhaps the Intel® Arc Control software component (or another related software piece installed alongside the driver) might be contributing to the instability, rather than just the core driver itself. Therefore, yesterday I installed the latest available WHQL driver, 32.0.101.6734. Crucially, this time I performed a driver-only installation, specifically choosing not to install the Intel® Arc Control software or any other optional graphics software components. As of now, the system has been running stably with this driver-only configuration for over 24 hours, including periods of idle time after RDP sessions, without any driver crashes or anomalies observed.
Additional Observation - VRAM Usage:
It's also worth noting that my PC is used for productivity and is almost never shut down. As a result, the graphics card's VRAM (Video Memory) usage tends to increase gradually over extended periods of uptime. Looking back, the driver crashes I experienced (both the original BSODs and the non-BSOD crashes with driver .6651) seemed more likely to occur when the dedicated GPU Memory utilization exceeded approximately 80%. This might be another factor contributing to the issue, potentially exacerbated by RDP state transitions or the Arc Control software.
Summary & Next Steps:
The preliminary results suggest that installing only the core graphics driver (.6734) without the accompanying Intel Arc Control software might mitigate or resolve the RDP-related crash issue. I will continue monitoring the system closely with this driver-only setup.
Regarding your previous request: While I haven't experienced a BSOD since switching to the driver-only installation of .6734, I still have the minidump file (040625-9125-01.dmp) from the original BSOD incident reported with driver .6653. If your team still requires it for analyzing the underlying cause (which might still exist even if Arc Control was the trigger for the crash), please let me know the preferred method for uploading it.
Thank you again for your support and investigation.
Patrick_Star_Y
RandyT_Intel
Hello @Patrick_Star_Y,
Quite interesting findings and a detailed report. Yes, kindly provide the crash dump. You can attach the file here, or if you're not comfortable, you may share it through email. Just let me know so I can send you a separate email. I will coordinate this concern internally and report back to you once I have completed our investigation. We value your feedback and are dedicated to improving our products.
Randy T.
Patrick_Star_Y
I am now almost certain that the Intel® Arc Control software  or one of its related components is causing the driver instability/anomalies.
As I mentioned previously, this time I installed driver 32.0.101.6734 using a driver-only method, without installing any of the associated software. With this configuration, the driver has been running very stably, and the computer has not experienced any driver-related issues whatsoever.
Patrick_Star_Y
RandyT_Intel
Thank you for sharing this information. I will begin investigating the issue and attempt to replicate it on our end. I'll post an update here or notify you directly once there are any developments. If I need further details, I'll reach out to you here. I appreciate your patience as I work on this matter.
Randy T.
RandyT_Intel
Thank you for sharing this information. I will begin investigating the issue. I'll post an update here or notify you directly once there are any developments. If I need further details, I'll reach out to you here. I appreciate your patience as I work on this matter.
Randy T.
RandyT_Intel
As we continue to investigate the issue you reported regarding the Intel Graphics Driver, we would like to gather a bit more information to ensure we address your concerns accurately.
Could you please clarify which application you are using for remote desktop support? Specifically, are you utilizing Quick Assist or Remote Desktop Connection? This information will help us better understand the context of the issue.
Additionally, we would like to know whether the computer with the Intel Arc B580 installed is the remote system you are accessing, or if it is the workstation you are using to access a remote desktop. This detail is crucial for our investigation.
Your feedback is invaluable to us, and we are committed to resolving this matter promptly. Thank you for your cooperation and assistance.
Randy T.
Patrick_Star_Y
Hello Randy T.,
Thank you for the follow-up questions. To clarify:
Remote Desktop Application: I am using the standard, built-in Remote Desktop Connection feature provided with Windows 11 Pro. This is the functionality enabled via Settings -> System -> Remote Desktop, which allows connection using the Remote Desktop app from another device. I am not using Quick Assist.
Role of the PC: The computer experiencing the BSOD is the one with the Intel Arc B580 installed. It is the remote system being accessed/controlled (acting as the RDP host). It is not the workstation I am using to initiate the remote connection (acting as the RDP client).
Further clarification: To be perfectly clear, I have not experienced any issues whatsoever when using this Arc B580 PC as the RDP client to remotely control other Windows devices. The BSOD problem only occurs when this specific PC (with the Arc B580) is the RDP host being controlled remotely.
Important Update on Stability: It is worth noting that since my last update where I installed the 32.0.101.6734 WHQL driver using the driver-only method (specifically without installing the Intel Arc Control panel or any other related graphics software), I have continued to experience complete stability. There have been no further BSOD occurrences whatsoever since making this change.
This significantly strengthens my suspicion, mentioned previously, that the BSOD issue was likely related to the accompanying software components (like Arc Control) rather than the core driver file (igdkmdnd64.sys) itself acting alone.
I hope this detailed information helps further clarify the scenario and aids in your investigation. Please let me know if you need any more details.
Have a great weekend!
Best regards
RandyT_Intel
Thank you for the updates. I will forward this clarification internally and post an update here to notify you once I have more information. I appreciate your patience as I look into this issue.
Randy T.
Ernesto_C_Intel1
I'm contacting you on behalf of my technician. Allow me more time to recreate the issue that you've encountered.
I'll provide an update as soon as possible.
Ernesto C.
Ernesto_C_Intel1
Hi @Patrick_Star_Y,
Thank you for responding to my technician. Allow me more time to further investigate the issue that you've encountered.
I'll provide you an update as soon as possible.
Ernesto C.
RandyT_Intel
Our team has attempted to simulate the problem but has been unable to reproduce it in our test lab. To better understand and address the issue, we kindly ask for the following information:
  1. How many systems are being affected?
  2. Are you using the same CPU/motherboard combination on all systems?
  3. How many cycles are usually needed to see the BSOD?
  4. What is the approximate failure rate? (e.g., BSOD occurs 1 out of 10 RDP connections)
  5. Can you run driver 101.6739 with IGS on a system that has had a clean OS installation? This will help us rule out any conflicts with IGS and third-party components.
Simulation: Remote Desktop Connection test - Intel Arc B580 GPU
Your cooperation in providing these details will greatly assist us in resolving the issue. Please let us know if you have any questions or need further assistance.
Randy T.
Patrick_Star_Y
Hello Randy T.,
Thank you for your reply and the request for more information. I will provide a detailed history of the issue and my system specifications.
Here is my system information, exported using HWInfo64 and compressed into a 7z file. You can view the full details after extraction.
Let me recount the history of this issue in detail:
1. Experience with Arc A770 (Late 2022):
At the end of 2022, I purchased an Intel Arc A770 16GB Limited Edition graphics card. At that time, my PC configuration was an AMD Ryzen 9 7950X CPU; the rest of the components were identical to those listed in the attached HWInfo64 report. During that period, I experienced intermittent Blue Screens of Death (BSODs) but couldn't initially determine the cause.
By chance, I discovered the trigger: when I connected to this A770 PC using Remote Desktop Connection, the connection would succeed and load the remote desktop, but after just a few seconds, the connection would drop. When I tried to reconnect, I found the PC had rebooted. Checking the BSOD logs revealed the Intel graphics driver (igdkmdnd64.sys) was the cause. As this issue severely hampered my workflow, I sold the A770 about a month later. I then used the integrated graphics of the 7950X for over half a year without encountering any BSODs.
2. Experience with AMD/NVIDIA GPUs:
Subsequently, due to my work involving GIS mapping and AI model training, I used both an AMD Radeon RX 7700 XT and an NVIDIA GeForce RTX 4070 Super in this same system (with the 7950X). I did not experience any BSODs with either of these cards.
3. Experience with Arc B580 (7950X and 9950X CPUs):
Eventually, I acquired the Maxsun Intel Arc B580 12G graphics card. Initially, while I was still using the AMD Ryzen 9 7950X CPU, I installed the WHQL driver 32.0.101.6734 using the driver-only method. Crucially, this configuration (7950X + B580 + driver-only) proved to be stable, and I did not encounter the BSODs with it.
Last week, I upgraded my CPU to an AMD Ryzen 9 9950X (other core components remained unchanged). I continued using the same Arc B580 card with the same driver-only installation of .6734. Since this CPU upgrade, the system has continued to be perfectly stable.
4. Hypothesis Based on Current Stability:
Based on the fact that the system is now completely stable with only the core driver installed (across both 7950X and 9950X CPUs with the B580), my strong suspicion falls on a potential bug within the Intel Arc Control panel software (or potentially another related software component installed alongside it).
I base this on an observation I made previously when Arc Control was installed (during the A770 period): If I connected to the PC via Remote Desktop and then tried to open the Intel Arc Control panel, it seemed to display some kind of "loading..." message (I can't recall the exact wording and cannot reproduce it now), and it would ultimately fail to load or display the Arc card's configuration details correctly within the RDP session. Could this specific behavior, where Arc Control struggles or fails to initialize properly during an active RDP session, be the underlying cause of the driver crash and subsequent BSOD experienced with the A770?
Regarding Your Specific Questions & Request:
This issue has primarily affected my single main workstation, detailed in the HWInfo64 file. The BSOD problem specifically occurred with the previous 7950X CPU combined with the Arc A770 when the full driver package (including Arc Control) was installed.
Subsequently, using the Arc B580 card first with the 7950X CPU and now with the current 9950X CPU, but always using the driver-only installation of .6734, has resulted in a completely stable system without experiencing any BSODs whatsoever.
The BSOD (when it happened with the A770) occurred intermittently, but I eventually discovered it was often associated with Remote Desktop Connection usage. While it didn't happen reliably seconds after every connection attempt, when these RDP-related BSODs occurred, they resulted in a system reboot which severely impacted my work.As the B580 has been stable with the driver-only install from the start (on both 7950X and 9950X), I haven't tracked failure rates or cycles for it, as there were no failures to track.
Regarding your request to test driver 101.6739 with IGS (Arc Control) on a clean OS install: When I upgraded to the 9950X CPU last week, I actually did perform a fresh, clean installation of the latest version of Windows 11. Following the clean OS installation, I installed the .6734 driver using the driver-only method. As mentioned, this setup (clean Win 11 + 9950X + B580 + driver-only .6734) has been perfectly stable with no issues whatsoever.
Given this confirmed stability on a clean OS without IGS/Arc Control, and considering the BSOD issues I previously had with the A770 when Arc Control was installed (especially the problematic behavior during RDP), I am still very hesitant to intentionally reinstall Arc Control (IGS) and potentially destabilize my now stable production environment just to test driver .6739 with it. The evidence gathered so far strongly points towards the software suite being the problematic component in this RDP scenario, even on a completely clean OS installation.
Based on my experiences across multiple GPU brands and the clear stability achieved only when omitting the Intel Arc Control software (both with the 7950X and 9950X CPUs paired with the B580), I strongly believe the investigation should focus on how Arc Control (or related components) interacts with the driver during an active Remote Desktop session on the host machine.
Thank you for your continued investigation. I hope this detailed history and my observations are helpful.
Patrick_Star_Y
