23099 Discussions
Pixel shader parameters are not respecting 'sample' interpolation modifier in Vulkan
Rob_S
System Setup Information:
System Used: Lenovo Thinkpad X1 Yoga 2nd Gen
CPU SKU: i7
GPU SKU: HD 620
Processor Line: U-Series
System BIOS Version: LENOVO N1NET33W (1.20)
CMOS settings: ???
Graphics Driver Version: 24.20.100.6286
GOP/VBIOS Version:
Operating System: Windows 10 x64
OS Version: 10.0.18362
API: Vulkan
Occurs on non-Intel GPUs?: No
Steps to Reproduce:
1. Set up 2x MSAA image + renderpass + framebuffer + graphics pipeline
2. Enable sample location shading during VkDevice creation
3. Use a pixel shader that has parameters (non-position inputs) that are interpolated with the `sample` modifier
4. Observe that the interpolation is still happening at the Pixel Center
5. Do not profit
Vulkan SDK installed: 1.1.130
Vulkan Instance version: 1.1.126
VkPhysicalDeviceProperties.apiVersion = 1.1.82
The position in the shader is correct, since I can see the geometry edges are what I expect them to be. Just the parameter interpolation is busted.
Rob_S
I am in the process of adding support for `VK_EXT_sample_locations` to my application. I added a populated `VkPipelineSampleLocationsStateCreateInfoEXT` struct to the pipelines which were giving me problems (for unrelated reasons). Once I tested it on my Intel laptop, suddenly, `sample` interpolation works on the pipelines in question?? I'm using the same sample locations as the default MSAA 2X ({0.75, 0.75}, {0.25, 0.25}).
Besides the process of adding the VK_EXT_sample_locations extension to my device creation process, here's some code of what I changed during pipeline creation:
        m_vk_pipeline_sample_locations_ext = {
        VK_STRUCTURE_TYPE_PIPELINE_SAMPLE_LOCATIONS_STATE_CREATE_INFO_EXT };
    m_vk_pipeline_sample_locations_ext.sampleLocationsEnable = VK_TRUE;
    m_vk_pipeline_sample_locations_ext.sampleLocationsInfo = {
        VK_STRUCTURE_TYPE_SAMPLE_LOCATIONS_INFO_EXT};
        .sampleLocationsPerPixel = VK_SAMPLE_COUNT_2_BIT;
        .sampleLocationGridSize = {1,1};
        .sampleLocationsCount = 2;
    // This is fake code, I don't really allocate this on the stack
    VkSampleLocationEXT sample_locs[] = { {0.75, 0.75}, {0.25, 0.25}};
         .pSampleLocations = &sample_locs[0];
    m_vk_pipeline_multisample.pNext = &m_vk_pipeline_sample_locations_ext;
