23094 Discussions
Playing Fallout Shelter causes Display driver stopped responding and has recovered
VLipe
I had no problem with graphics until I started play https://www.microsoft.com/en-us/store/p/fallout-shelter/9nblggh556n4 Fallout Shelter . After playing this game some time (cca 20 hours) it started crash (TDR) about every 5 minutes. I tried many version of driver (including latest Beta 15.45.4614) and with all drivers I have same behavior and I can reproduce it at 100%. On other computers (including different Intel graphic card) same game does not crash.
My configuration:
Asus Zenbook UX305CA
CPU: Intel Core M5 6Y54 Skylake,
OS: Windows 10 14393
GPU: Intel HD Graphics 515
RAM: 8GB
I forced Windows to do BUG CHECK instead of resetting driver so I have also minidump and I can provide it (or test other things). Here is some info from WinDbg:
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 10.0.14393.693 (rs1_release.161220-1747)
SYSTEM_MANUFACTURER: ASUSTeK COMPUTER INC.
SYSTEM_PRODUCT_NAME: UX305CA
SYSTEM_SKU: ASUS-NotebookSKU
SYSTEM_VERSION: 1.0
BIOS_VENDOR: American Megatrends Inc.
BIOS_VERSION: UX305CA.300
BIOS_DATE: 06/08/2016
BASEBOARD_MANUFACTURER: ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT: UX305CA
BASEBOARD_VERSION: 1.0
DUMP_TYPE: 2
BUGCHECK_P1: ffffda89a3a5d010
BUGCHECK_P2: fffff80d9ae42f60
BUGCHECK_P3: 0
BUGCHECK_P4: 1
FAULTING_IP:
igdkmd64+12f60
fffff80d`9ae42f60 4055 push rbp
DEFAULT_BUCKET_ID: CODE_CORRUPTION
CPU_COUNT: 4
CPU_MHZ: 5e8
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 4e
CPU_STEPPING: 3
CPU_MICROCODE: 6,4e,3,0 (F,M,S,R) SIG: 8A'00000000 (cache) 8A'00000000 (init)
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x116
PROCESS_NAME: System
CURRENT_IRQL: 0
ANALYSIS_SESSION_HOST: WALLY-I5
ANALYSIS_SESSION_TIME: 02-26-2017 19:25:34.0257
ANALYSIS_VERSION: 10.0.14321.1024 amd64fre
STACK_TEXT:
ffff9c01`dab7b748 fffff80d`989fba88 : 00000000`00000116 ffffda89`a3a5d010 fffff80d`9ae42f60 00000000`00000000 : nt!KeBugCheckEx
ffff9c01`dab7b750 fffff80d`989fb1ac : fffff80d`9ae42f60 ffffda89`a3a5d010 ffff9c01`dab7b859 00000000`00000000 : dxgkrnl!TdrBugcheckOnTimeout+0xec
ffff9c01`dab7b790 fffff80d`9ba277b5 : ffffda89`a3a5d010 00000000`001687d0 00000000`00000009 fffff80d`9889909d : dxgkrnl!TdrIsRecoveryRequired+0x1ac
ffff9c01`dab7b7c0 fffff80d`9ba83842 : ffffda89`a814b000 00000000`00000002 ffffda89`a814b000 ffffda89`a814d000 : dxgmms2!VidSchiReportHwHang+0x4c1
ffff9c01`dab7b8c0 fffff80d`9ba62b87 : 00000000`00000002 00000000`0000e5ac 00000000`001687d0 00000000`00000001 : dxgmms2!VidSchiCheckHwProgress+0x20772
ffff9c01`dab7b930 fffff80d`9ba0a4b4 : ffffda89`a8714550 ffffda89`a814d000 ffffda89`a8714558 00000000`00000002 : dxgmms2!VidSchiWaitForSchedulerEvents+0x337
ffff9c01`dab7b9f0 fffff80d`9ba6ec1f : ffffda89`aa273700 ffff9c01`dab7bb50 ffffda89`aa273700 ffffda89`00000000 : dxgmms2!VidSchiScheduleCommandToRun+0x3d4
ffff9c01`dab7bb00 fffff80d`9ba6ebe0 : ffffda89`a814d500 ffffda89`a814d000 00000000`00000080 fffff80d`9ba6eb60 : dxgmms2!VidSchiRun_PriorityTable+0x2f
ffff9c01`dab7bb50 fffff801`33c86729 : ffff9c01`d7580180 fffff801`33dd3adf 00000000`00979189 ffffda89`a814e7c0 : dxgmms2!VidSchiWorkerThread+0x80
ffff9c01`dab7bb90 fffff801`33dd3bb6 : ffff9c01`d7580180 ffffda89`a814e7c0 fffff801`33c866e8 00000000`00000000 : nt!PspSystemThreadStartup+0x41
ffff9c01`dab7bbe0 00000000`00000000 : ffff9c01`dab7c000 ffff9c01`dab75000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: kb
CHKIMG_EXTENSION: !chkimg -lo 50 -d !nt
fffff80133cee9bd - nt!MiInsertNonPagedPoolOnSlist+45d
[ f6:c2 ]
1 error : !nt (fffff80133cee9bd)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: ONE_BYTE
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_ONE_BYTE
PRIMARY_PROBLEM_CLASS: MEMORY_CORRUPTION_ONE_BYTE
TARGET_TIME: 2017-02-26T16:22:34.000Z
OSBUILD: 14393
OSSERVICEPACK: 693
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 784
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS Personal
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: 2016-12-21 07:50:57
BUILDDATESTAMP_STR: 161220-1747
BUILDLAB_STR: rs1_release
BUILDOSVER_STR: 10.0.14393.693
ANALYSIS_SESSION_ELAPSED_TIME: 1608
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:memory_corruption_one_byte
FAILURE_ID_HASH: {ad110d6a-3b33-2c0a-c931-570eae1ba92d}
fffff80d`9ae30000 fffff80d`9b8e0000 igdkmd64 T (no symbols)
Loaded symbol image file: igdkmd64.sys
Image path: \SystemRoot\System32\DriverStore\FileRepository\igdlh64.inf_amd64_463164d40c3d26ce\igdkmd64.sys
Image name: igdkmd64.sys
Browse all global symbols functions data
Timestamp: Fri Nov 11 20:21:37 2016 (58261A41)
CheckSum: 00A918F0
ImageSize: 00AB0000
Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4
Hello Wally_,
Thank you for contacting the Intel community.
This error shows that there was a time-out error accessing the Video card. This can be caused by software (drivers or applications) or hardware (GPU, RAM or Motherboard). Please bear in mind that since driver version 15.40.22.4424 this issue was resolved, all drivers since that date include this fix. You already tried known good working drivers, so I would suggest trying the following:
Uninstall the Beta driver; please see http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver and Intel® Display HDMI/Audio Driver
Once the Beta driver is uninstalled, go ahead and install the driver version https://downloadcenter.intel.com/download/26563/Graphics-Intel-Graphics-Driver-for-Windows-15-45-?product=88354 4590 manually, please check how to http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows 8*/8.1*
NOTE: The driver or software for your Intel® component might have been changed or replaced by the computer manufacturer. We recommend you work with your computer manufacturer before installing our driver so you don't lose features or customizations.
Ensure that your Microsoft* operating system is up to date and as well the Microsoft* .NET Framework software. Some issues (such as the stopped responding/successfully recovered error message) can be fixed with a simple update to the systems .NET Framework* software. This software is available from the https://www.microsoft.com/en-us/download/details.aspx?id=30653 Microsoft Web site.
If the issue persists contact your computer manufacturer and install their latest driver, uninstall the Intel® generic driver and install the driver from ASUS. Original Equipment Manufacturers (OEM) may have customized the generic Intel® Drivers to match their specifications or requirements.
All OEMs should have access to newer Intel® graphics driver versions that contain this fix.
https://www.asus.com/us/Notebooks/ASUS-ZenBook-UX305CA/HelpDesk_Download/ https://www.asus.com/us/Notebooks/ASUS-ZenBook-UX305CA/HelpDesk_Download/
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Ivan.
VLipe
Hello Ivan (intel_corp),
thank you for general answers. But what I need is technical solution how to find where is problem. You mentioned some type of drivers that should I try. But I tried all you mentioned, detaily:
20.19.15.4364 (From Asus page you mentioned)
20.19.15.4474 (From Asus)
21.20.16.4550 (these are automatically installed by Windows Update)
21.20.16.4614 (beta manually installed from Intel side)
And all have same behavior - graphic driver reset after few minutes of playing. All! That means installing driver from Asus did not helped, installing latest beta did not helped, installing from Windows update did not helped. So my private bet that problem is somewhere in graphic driver regarding to Skylake chipset. It somehow possible to diagnose which call to hardware stuck? Or if you don't know it, can you direct me where could I ask question leading to real solving this issue?
Of course, it can be also hardware problem, but when it is hardware problem, typically there is problem with more different applications (not my case, I have problem only with this game). And also I run HW tests and all passed OK (even this https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool Download Intel® Processor Diagnostic Tool). Do you have some tips what to try to confirm that this is (or is not) problem in hardware?
And about Microsoft* .NET Framework: can you explain me, how framework working strictly in user space can affect kernel driver or hardware except bug in driver? I don't think this update can help in this TDR. But for to be sure: computer is up to date with latest updates released from Windows update.
Thanks for help
Vaclav
Hello Wally_,
Thank you for the information, please bear in mind that our latest driver have already address this issue, this issue has been resolved since the driver update mentioned above, since this is a Laptop, your best contact support at this point is with your system manufacturer as they are more familiar with your system and how all the components interact with each other.
Normally we don't have all the equipment from all of our partners to replicate this issue with this specific system you have, so you will need to ask Asus for them to try to replicate the issue with a system similar like yours and see if they get the same problem, if they don't experience this behavior you should request a replacement directly from them.
I sent you a private message.
Ivan.
