23104 Discussions
Please respond to the post you closed about Intel DS&A fighting with Windows Update
GraniteStateColin
See:
https://community.intel.com/t5/Graphics/Intel-Driver-amp-Support-Assistant-Still-Fighting-with-Windows/m-p/1468107/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExGSTc1U09FM1QxWVE0fDE0NjgxMDd8U1VCU0NSSVBUSU9OU3xoSw#M115438
You said you were going to close it instead of answering my question and to launch a new post. So here's the new post. Please respond there in that original post.
Hugo_Intel
Hello GraniteStateColin
Thank you for posting on the Intel Communities. I am sorry you are experiencing this issue when trying to install the latest driver for your system as well l apologize since I am not able to post the reply on the original thread as it is already closed, however, I will be glad to assist you under this new thread.
Answering your questions from the previous thread I want to let you know that the response and information shared by @MRoss5200 is accurate and correct, as he mentioned Windows identifies each driver in a different way and prioritizes the driver from the system's vendor as it is customized for the system and it is why Windows keeps rolling back the driver to a previous version.
In order to fix this issue you can follow the steps outlined in the following article:
Intel® Driver & Support Assistant (Intel® DSA) Keeps Prompting for Same Graphics Update
You can skip the part about hiding the update since I understand you want to keep the driver updated, however, the first part of the troubleshooting should fix the issue. Let us know the results.
Hugo O.
Hugo_Intel
I hope you are doing fine.
Hugo O.
Hugo_Intel
We are interested in helping you get this issue resolved. If you happen to still experience the same behavior we would like to ask you for the log files folder from Intel® Driver & Support Assistant (Intel® DSA), you can follow these instructions to get them:
How to Obtain the Intel® Driver & Support Assistant (Intel® DSA) Folders?
Hugo O.
Hugo_Intel
Please let us know if you are still experiencing this issue, and if so, please share with us the information requested in my previous post.
Hugo O.
Hugo_Intel
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
GraniteStateColin
Of course I'm still experiencing the issue. Has Intel fixed it? Have you provided any solution? No and no, therefore, obviously, I'm still experiencing the issue.
