- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello All,
We have been investigating a problem with the Pokemon TCGO game and we need your help you identify what the problem is. Based on feedback we have received, it seems the game crashes when in a match or sometimes randomly.
Here are some steps I want you to do:
1. Uninstall the current graphics driver. You can get instructions to do this at the following link:
http://www.intel.com/support/graphics/sb/CS-034574.htm Uninstalling the Intel® Graphics Driver and Intel Display/HDMI Audio Driver
2. Download the latest graphics driver here:
2500/4000/4200/4400/4600/5000:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23638 32 bit
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23639 64 bit
3000/2000:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3319&DwnldID=23376 32 bit:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=3319&DwnldID=23377 64 bit:
3. Confirm with the game developer if they have a patch or firmware available for this game.
4. Update the BIOS using the latest provided by the Computer Manufacture.
If you do these steps and issue persists, please attach your graphics report and the dxdiag report here.
How to get it?
Dxdiag Report: Type dxdiag in Start Menu> open> Save> Copy/Paste here.
Graphics Report: Right click on desktop> Graphics Properties> Options> Drop Down Menu> Information Center> Save> Open .txt file created> Copy/Paste here.
Also it would be very helpful to know what are the exact steps you are taken to reproduce the problem along with images of the problem.
We appreciate your help!
Kevin.
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi
I have an Asus Transformer Book T100 and the problem with TCGO is not solved yet.
After sarting the game, after a randomly period of time the game craches.
After reading several foruns, it seems that the problem relies in the Intel HD Graphics together with windows 8.1.
I already have the latest Graphic driver and BIOS.
As requested I attach the DxDiag.txt
System Information
Time of this report: 3/11/2014, 21:47:44
Machine name: ASUS100T
Operating System: Windows 8.1 32-bit (6.3, Build 9600) (9600.winblue_gdr.131030-1505)
Language: Portuguese (Regional Setting: Portuguese)
System Manufacturer: ASUSTeK COMPUTER INC.
System Model: T100TA
BIOS: T100TA.227
Processor: Intel(R) Atom(TM) CPU Z3740 @ 1.33GHz (4 CPUs), ~1.3GHz
Memory: 2048MB RAM
Available OS Memory: 1934MB RAM
Page File: 3587MB used, 1084MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.03.9600.16384 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0F31&SUBSYS_14ED1043&REV_09
Display Memory: 998 MB
Dedicated Memory: 32 MB
Shared Memory: 966 MB
Current Mode: 1368 x 768 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: HYD HV101HD1
Monitor Id: HYD044E
Native Mode: 1368 x 768(p) (60.103Hz)
Output Type: Internal
Driver Name: igdumdim32.dll,igd10iumd32.dll,igd10iumd32.dll
Driver File Version: 10.18.0010.3355 (English)
Driver Version: 10.18.10.3355
DDI Version: 11
Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: Thread group
Miracast: Not Supported by WiFi driver
Hybrid Graphics GPU: Integrated
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: 11/13/2013 23:35:36, 11433984 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4C71-11CF-E87E-E734B4C2C735}
Vendor ID: 0x8086
Device ID: 0x0F31
SubSys ID: 0x14ED1043
Revision ID: 0x0009
Driver Strong Name: oem121.inf:5f63e534a222b607:iVLV2M_w81:10.18.10.3355:pci\ven_8086&dev_0f31&subsys_14ed1043
Rank Of Driver: 00DA0001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend Deint...
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Lemi,
I have been testing the game on a system with Win 8.1 but I have not been able to reproduce it yet. Can you please provide an image if the error so we can provide this feedback to development team?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi
The error is the windows generic error. See the image.
https://dl.dropboxusercontent.com/u/48554738/Pokemon.jpg https://dl.dropboxusercontent.com/u/48554738/Pokemon.jpg
The error box is in Portuguese but is syas that "Pokemon.exe has stopped work. Windows is finding a solution". As obvious, like for all windows errors, the solution is never found!!!!
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Is there any way so i can debug the error (some kind of software or procedure in order to help you) ?!
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I am afraid to say that from our side we do not have a debug tool for this but I will check on this. In the meantime, you can try updating the graphics driver to the latest. Here is the download link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23644 https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23644
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Ok. I'll start testing the latest driver.
I'll keep you posted after cheking a few games.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have tried to intal de 32 bit version of the driver that you have sent me but the setup gives me an error at the beginning saying that my computer doesn't gather the conditions to install these drivers!!!!
Using the Intel Driver Update utility it says that my driver is current
Product Detectedhttp://www.intel.com/support/graphics/sb/CS-034553.htm Intel® HD Graphics for Intel® Pentium® and Celeron® ProcessorsCurrent Driver Installed10.18.10.3355Your driver is current.- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for the information. I have been checking and It seems I provided the incorrect driver. Researching from my side, the driver we have for the graphics controller is this:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23321 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23321
But this driver is for the processor models listed under "Detailed Description" so at this point have you tried the driver provided by your Computer Manufacture?
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Once again thanks for your replay. Nevertheless, the drivers that you suggested are for 64-bit and the Asus T100 has a 32-bit processor.
As I mentioned before I have the PC up to date regarding BIOS and drivers from the manufacturer.
I'll be waiting for more suggestions.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I understand and thanks for your patience. We are still checking on this.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I really understand the frustration for waiting this time. I really thank you for your patience. I am constantly checking with development team but at this point I have no updates on this. I will check again with them.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Sorry once Again. We are still investigating towards a solution. I will have an answer in the worst case by next Wednesday.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi all,
During our investigation we have see the error ntdll.dll which is related to the network traffic. So as another troubleshooting step, can you update the network driver or wireless driver (depending on the case)?
I know it sounds weird but it is just a troubleshooting step. Thanks for your patience.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thanks for the tips, but I have all my drivers up to date from Asus oficial wb site. In this case I have the Broadcom Wireless Lan Driver and Application version V5.93.99.187.1 from 13-03-2014.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Lemi,
Guys I completely understand this is frustrating but can you please provide Step by Step how to reproduce the issue. If you can add pictures will be great!
Besides this, can you again try installing the latest BIOS update for your computer and the latest graphics driver?
Here is the download link for the Graphics driver:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23714 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=23714
Let me know.
Kevin M
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Guys we are working and investigating so I would like to know if the issue has been fixed with the steps provided before.
If there are no comments or feedback I will consider it as fixed.
Kevin M
