Hi everyone, Last week I tried to replay Batman: Arkham City on Steam, but I’ve been running into performance issues. Whenever the cutscenes start, they lag heavily and the framerate drops to around 10–14 fps.
I attempted to fix it by installing NVIDIA PhysX and replacing some game files, but unfortunately that didn’t solve the problem.
System specifications:
Motherboard: Gigabyte B550M DS3H AC R2
CPU: AMD Ryzen 5 5600G
GPU: Intel Arc B580
RAM: HyperX 16GB (2×8GB) 2400MHz
PSU: Corsair CX Series CX750 (750W, 80 Plus Bronze)
Storage: Toshiba 3TB HDD (no SSD)
Hi Leandroflash05,
Thank you for reaching out to the Intel Community Forum. I appreciate your message, and I want to assure you that I’m here to help you resolve this issue. To better understand the situation and provide the most accurate support, could you please provide the following information:
- Are the lag issues occurring only during cutscenes, or do they appear during regular gameplay as well?
- Have you already tried verifying the integrity of the game files through Steam?
- What in‑game graphics settings are you currently using? If possible, please include screenshots so we can review them.
- What are your CPU and GPU usage levels during the cutscene lag spikes?
- Did this problem begin immediately after installing the game, or did it develop gradually over time?
- Are there any background applications running that might be consuming system resources?
- Have you attempted using different compatibility modes or adding specific launch parameters for the game?
- Is your RAM operating at the correct speed (2400 MHz) and in a dual‑channel configuration?
- What are your system temperatures while gaming?
Additionally, to help us better understand your system configuration and ensure we provide the most accurate troubleshooting steps, we kindly ask that you share the Intel® System Support Utility (SSU) report from your device. This report includes detailed information about your hardware and software environment, which is essential for diagnosing the issue effectively.
Please follow these steps:
- Download and run the Intel® SSU application.
- Allow the tool to generate a text file containing your system information.
- You may refer to this guide for detailed instructions: Help Guide for the Intel® System Support Utility
- Once complete, please attach the generated file to your reply.
If you have any other questions or need further assistance, please feel free to let us know. We’re here to help.
Kent Russel P.
Hi @KentRusselP_Intel
About these questions:
- The lag occurs only during cutscenes; it does not occur during gameplay.
- Yes, but it didn't work.
- I use Very High settings, with NVIDIA PhysX hardware acceleration enabled.
- CPU usage is around 60%–70%, and GPU usage is at 100%.
- It started when I opened the game for the first time with the Intel Arc B580.
- Are there any background applications running that might be consuming system resources?No. I tested disabling the antivirus, but without success.
- Have you attempted using different compatibility modes or adding specific launch parameters for the game?Yes. I ran it in Windows 7/8 compatibility mode and applied a parameter to force the game to run in DX9, but it didn’t work.
Yes. - What are your system temperatures while gaming?
The temperature is 56°C while gaming.
Correction: The NVIDIA PhysX hardware acceleration is disabled.
Hi Leandroflash05,
Thank you for your response, please try to do a clean installation of Intel Graphics Driver 32.0.101.8509 WHQL Certified using Display Driver Uninstaller (DDU). Here is the link for your reference: Clean Installation of Intel® Graphics Drivers in Windows*
If you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
i made a clean installation using Display Driver Uninstaller (DDU), but still with lag and framerate drop in Batman Arkham City game.
Hi Leandroflash05,
Thank you for your response, for further investigation and analysis of the issue, please provide the following:
1. Latest SSU logs of your system. Please follow these steps:
- The tool will generate a text file containing your system information.
- Refer to this guide for detailed instructions: Help Guide for the Intel® System Support Utility
- Once completed, please attach the generated file to your response.
2. CapframeX is a tool for frametimes capture and analysis. Please follow these steps:
1. Go to https://www.capframex.com/download and download the latest version of CapframeX.
2. Go to https://www.guru3d.com/files-details/rtss-rivatuner-statistics-server-download.html and download the latest version of RTSS.
3. Unzip both installers and install them.
4. Download this file OverlayEntryConfiguration_0.json (attached at the bottom of this article) with the recommended RTSS configuration.
5. Paste this file to %userprofile%\Documents\CapFrameX\Configuration.
6. In the Capture tab, set the "Capture time" to 0. This is to remove the preset limit in capture time.
7. In the Overlay tab, uncheck "Auto-Disable OSD" and click the save icon.
8. Click the setting icon (cog wheel icon on the top right) and set the "Capture file mode" to "JSON + CSV"
Capturing the Performance Data
1. Open CapframeX and do NOT minimize or close it close.
2. Open the game and go to the part of the game you need to be to repro the issue. You should see the RTSS overlay in the top left corner of your screen, with the status "<game name> ready to capture…".
3. Press F11 to start capturing data and reproduce the issue. The Status in the overlay will change to "Recording frametimes XX s".
4. Once you have reproduced the issue, press F11 to finish the data capturing. The Status in the overlay will change to "Processing data".
5. Back to CapFrameX, you can find all the data captures in the left panel of the Analysis tab. Clicking any one of these captures will display the results on the right.
6. To attach both the captured .json and .csv files to your escalation.
Kent Russel P.
Here are the files about the system configuration and the game performance with CapframeX.
Hi Leandroflash05,
Thank you for getting back to us and for providing the requested logs. Rest assured that we will thoroughly investigate the issue. In the meantime, if you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
