22895 Discussions
Problema para actualizar mi driver de graficos. Intel pentium P6100
CZava2
Tengo una acer aspire 7741z con un procesador intel pentium p6100 2.0 ghz con intel graphics HD con un driver version 8.15.10.2189, mi problema es que esta version del driver tiene una version de OpenGl 1.1, esto me limita en alguna aplicaciones que funcionan con versiones mas actuales al menos 3.0 en adelante, pero no puedo encontrar ninguna actualizacion para este chipset, ni en la paguina de intel ni en la del fabricante acer. Podria indicarme cual seria la version correcta para poder actualizar el driver de mi chipset de video?
Which version of Windows do you have? Also, Is it 32- or 64-bit?
Allan.
CZava2
Hi Allan
Its Win 7 64-bit my laptop is a Acer 7741z with intel pentium p6100 2.0 ghz processor, i try the manufacturer driver, but its the same version that i have with OpenGl 1.1, and i can find any update U.u
Jan.
CZava2
Dont, when i try with de .exe file. say's "This system does not meet the minimum requirements to install this software" then i try to install manually but its the same thing, say than some problem ocurred during the install this software it couldnot be installed. what can i do?
Jan.
CZava2
it did not work, only display this message: The Driver being installed is not validated for this system. Get the appropriate driver by the system manufacturer . It will exit the installation program" ... ... ... HELP
Jan.
It seems the driver you need has to come from your computer manufacturer.
Please try accessing your computer manufacturer's web site and look for drivers for your computer model: http://www.acer.com/ac/es/ES/content/drivers http://www.acer.com/ac/es/ES/content/drivers
Allan.
