I am running on an Acer Aspire Z5600 all-in-one Processor is Pentium Dual-Core E5400 @ 2.70 GHz 2.69 GHz I have 3 gig of memory installed
Running WIndows 7 Premium Home - 64-bit Operating System Intel G45/G43 Express chipset.
When I got the system of few months ago it worked fine. I got it mainly to play Sims 3 and a couple other games (previously ran on a Gateway craptop) Sims 3 played fine..had no problems. Last week my computer did a Windows update and I noticed that whyenever my computer started to go into the screensaver it first ran this odd graphics test (at least I am assuming it some odd test) The screen did the following...it turned black, then gray, then white, then it has 4 horizontal bars (red, green, blue and white I think) the the screen went full blue and then the screensaver kicked. I didn;t think too much of it until I decided to go play SIms 3 yesterday. As soon as I hit play on the launcher I got the graphics test only this time it repeated over and over until I repeatedly it alt-tab, broke it to the desktop and then used the task manager to end the program. I went and checked my graphics resolution (SIms 3 hates anything over 1400 x 1060 apparently) and found my res had been set to the max 1920 x 1080. I figured aha! I found the problem and clicked a lower res and hit apply...bang! Went into the dang graphics test thing again. So I guess the problem is not being able to change the res (and yes I tried to do it thru the windows control panel and yes I had the same results) I have the latest drivers...just did a disk clean, reg clean, did a troubleshoot on everything and still no joy. I can play Sims 3 in windowed mode no problem but thats it. I have no clue where to do now. I'm not a puter whiz by any means so I seriously need to be handhel here...Thanks!
i have the same problem with all games i try on the same system also looking for help on this topic
bump
I'm wondering why this hasn't been solved if it's been a problem for a while.
I have the exact same problems as the others -- Windows 7 Home Premium, 64-bit OS, Intel G45/G43 Express Chipset.
Now, I got my computer from Gateway, and I never had all these problems, but once I got this strange virus and had to completely format my computer of everything on it, I needed to buy the OS again, and after installing it, this problem began to occur.
I think that it probably has a lot to do with the fact that I am now using an Intel graphics driver...but I am confused as to what to do to fix this...
But come on guys, where's the customer service? There's a banner at the top of my window right now with a bunch of happy people getting their problems solved.
I'm seriously reconsidering ever buying anything that involves Intel with this kind of lack of support coupled with other things I've heard.
I rolled back my driver/GMA (graphics media accelertor) to an earlier version and have not allowed windows to update it since. Everytime it updated I had problems. I uninstalled the GMA, rebooted my computer and let windows reload the old version and viola! no problems. I did test my theory that it was the update of the driver/GMA that caused the problem so I allowed the update to install and bang! same ol problem...uninstalled GMA, rebooted, reinstall and it works!
http://support.gateway.com/us/en/product/default.aspx?modelId=2324 http://support.gateway.com/us/en/product/default.aspx?modelId=2324
Go there and download (and install) the second VGA driver. It should work with the G45/G43 on Windows 7 Home Premium -- it does for me, and completely fixed my problem.
