18911 Discussions
¿Puedo usar i3 10110u para editar videos y para jugar cs go minecraft?
Aldo
¿Puedo usar i3 10110u para editar videos?  Que se utiliza en portátil Acer i3 8gb ram y 256 ssdd con gráficos integrados ...
n_scott_pearson
Super User Retired Employee
You certainly can.
Video Editing can be very I/O-bound. I thus recommend you get the fastest SSD possible. I would look for a laptop that utilizes M.2 socket for SSD and supports the faster NVMe SSDs.
Hope this helps,
David_G_Intel
Hello @Aldo
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
We also recommend that you check the minimum requirements of the video editing software that you want to use, just to make sure it will run smoothly. Update your operating system, drivers and software to the latest version.
If you need any additional information, please submit a new question as this thread will no longer be monitored.
David G
Intel Customer Support Technician
