Community
cancel
Showing results for
Search instead for
Did you mean:
EDavi7
Radeon RX Vega M GL Lag (HP Spectre x360 15t)
I recently bought the laptop specified in the subject and am having severe issues with frame rate and lag whilst running any online or offline games.
I have attached the DxDiag files.
I was running Counter Strike: GO and Skyrim: Special Edition on low settings.
Thank you for your help.
Tags (1)
EDavi7
Here is the SSU results:
Community Manager
Hello, eydavies. Thank you very much for sharing your issue with the Intel Communities Team. I will be more than glad to assist you.
Firstly, please try updating your graphics drivers to the latest version provided by Intel (18.6.1). Here is the download link: https://downloadmirror.intel.com/27881/a08/GFX_Radeon_Win10_64_18.6.1.exe https://downloadmirror.intel.com/27881/a08/GFX_Radeon_Win10_64_18.6.1.exe
Please be aware that the driver I am sharing with you is a generic driver from Intel® and some features of it might not be available for your machine, we always recommend verifying if there is any update with the manufacturer of the computer. Nevertheless, we can try to perform this troubleshooting step.
Then, I would like to know which is the frame rate that you are having while playing these games. Additionally, is this laptop connected to an external display or you are using the built-in display?
Antony S.
Community Manager
Hello, eydavies.
I would like to double check if you were able to perform the troubleshooting steps that I attached to the post above and the results.
Antony S.
