23282 Discussions
Raid 5 - Hot expanded 3 drive to 5 drive and converted to dynamic disk, now array broken
Gday ALL,
I just hot expanded my Raid 5 array, and all went great. i upgraded from a 3 disk Raid 5 system to a 5 Dsk Raid 5 system.
I then wanted to expand the partition size, so i converted to a dynamic disk, and thought i'd restart the server, before doing an expansion. well i was wrong there as when i brought the server back up the boot drive (seperate to the raid 5 array) booted, but the raid 5 dynamic disk is showing as unreadable.
So i ran dmview /v and it shows the partition table on the raid 5 drive as having 0 cylinders and most of the rest of the info is zero.
Can anyone suggest an easier way then restoring 2TB of backup files to recover the data, prefeably through fixing the partition table? ANy suggestions would be greatly appreciated.
Here is the output of DMview /V
---------- Partition Table Info Disk 1 ----------
0 Cylinders
1 Tracks/Cylinder
1 Sectors/Track
512 Bytes/Sector
12 MediaType
0 Sectors (total)
0 Bytes (total)
0 KB
0 MB
0.0 GB
0 StartingOffset
0 PartitionLength
0 HiddenSectors
0 PartitionNumber
0 PartitionType
0 BootIndicator
0 RecognizedPartition
0 RewritePartition
IOCTL_DISK_GET_DRIVE_LAYOUT_EX failed (error 21)
0 Bytes ( 0 sectors) Geometric size
0 Bytes ( 0 sectors) True size (measured)
0 Bytes ( 0 sectors) Reported size (Partition0)
0 Bytes ( 0 sectors) missing/wasted
---------- DMIO Kernel List ----------
Basic-info: version=21 maxspecio=512 maxio=512 maxkio=2048
Ktrans-state: dg=0.0 pendtid=0.0 state=UNKNOWN
# Kmem-regions:
# Disks: (cnt: 0)
# Devices: (cnt: 0)
# Groups: (cnt: 1)
Group NULLDG: iid=0.0 id=
diskset=00000000-0000-0000-0000-000000000000
configtid=0.0 logsize=0
kflag=()
vflag=(created|notempdb|noautoreimport|secondary)
# Group-Objects: (cnt: 0)
# End-group: NULLDG
---------- LDM Disk Header Harddisk0 ----------
ERROR: scan operation failed:
A format error was found in the private region of the disk
---------- LDM Disk Header Harddisk1 ----------
ERROR: Cannot get disk layout:
The device is not ready.
---------- LDM Disk Config Harddisk0 ----------
---------- LDM Disk Config Harddisk1 ----------
---------- LDM Disk KLOG Harddisk0 ----------
---------- LDM Disk KLOG Harddisk1 ----------
---------- DMAdmin Simple Query ----------
dmdiag: ERROR: No disk groups loaded
---------- DMAdmin Verbose Query ----------
