22857 Discussions
Rapid Storage Technology Software will not let me make any changes
I right click and select 'run as Administrator' to start the RST manager. Everything looks fine, but none of the options described in the help file are available. E.g. Manage Volume - all I have is Rename, Disable Write-back cache and Verify.
I currently have a RAID 0 w/ 2 1 gig HDs and a new 2gig HD. The only option i have for the new drive is 'Mark as spare' and 'Activate port LED'.
Is there a way to undo the RAID 0 and turn it into a RAID 1? Or can I use the 2gig drive and make a RAID 1 out of the RAID 0 and the new drive?
The purpose of the computer has changed and performance is not that much of a factor anymore.
