22925 Discussions
Registry Intel and Avalon.Graphics settings
MyTimeTheBest
Is it possible in Registry settings in Avalon.Graphics (Computer\HKEY_CURRENT_USER\Software\Microsoft\Avalon.Graphics) to be set frequency of the Display by adding extra "String Value", with the best possible option: GDZF (as is for Example RTX for a display to be universal)? Does that change the view of the display? I believe the display changes... What do those extra "String values" or "DWORD" values mean to Windows operating system?
And is it possible to divide the frequencies of the display by adding registry new "Keys": "New Key #1", "New Key #2", "New Key #3", with each folder containing a String Value FFFFFFFF having Value Data: FFFFFFFF...
What actually happens when we modify codes under the Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Intel\Display\igfxcui\MediaKeys as are: AceLevel FFFFFFFF, ProcAmpContrast FFFFFFFF, SharpnessFactor FFFFFFFF, EnableACE 1, EnableFMD 1, EnableSTE 1, EnableTCE 1, InputYUVRangeApplyAlways 1, NoiseReductionEnabledAlways 1,ProcAmpApplyAlways 1,  SharpnessEnabledAlways 1, SkinTone FFFFFFFF, SuperResolutionEnabled 1 ?
With all this I believe that a display then looks different also then and an image is sharper and more beautiful, somehow a display has a universal climb...
Will we have an option in Intel Arc Control or through Intel Graphics Command Center to change these options?
JedG_Intel
Hello MyTimeTheBest,
Thank you for posting at Intel Community Forum.
I'll be coordinating your concern to our team for further information.
We will let you know as soon as we have an update.
Jed G.
JedG_Intel
Hi MyTimeTheBest ,
Good day,
After coordinating this with the team, we would like you to know that modifying the registry settings can have an effect on how your display behaves but please note that modifying the registry settings have risks and should be done with caution.
For us to further investigate on your inquiry, please share the following information.
1.Are you using a specific Intel graphics card?
2.Are you experiencing any display issues hence why you'd like to modify the registry settings?
Additionally, to have a better understanding of your system configuration please generate System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
I look forward to your response!
Jed G.
MyTimeTheBest
Dear Jed,
1. I am sending you here Intel System Support Utility report where you can find details about "Intel(R) Iris(R) Xe Graphics" I have...
2. I was not experiencing any display issues, nor I am now...
Best Wishes
VARADHARAJAN
Valued Contributor II
@MyTimeTheBest
I found the following page for your reference
docs-desktop/dotnet-desktop-guide/framework/wpf/graphics-multimedia/graphics-rendering-registry-settings.md at main · dotnet/docs-desktop · GitHub
docs-desktop/dotnet-desktop-guide/framework/wpf/advanced/graphics-rendering-tiers.md at main · dotnet/docs-desktop · GitHub
Currently, I am using a desktop with Nvidia RTX 3060 as the primary   display
I also have a laptop i5 7200U  processor with an Intel GPU primary display and Nvidia 940mx as secondary
I  added the following registry keys in the Windows laptop
Windows Registry Editor Version 5.00
; Avalon Graphics keys added
[HKEY_CURRENT_USER\Software\Microsoft\Avalon.Graphics]
"MaxMultisampleType"=dword:00000004
"DisableHWAcceleration"=dword:00000000
"EnableDebugControl"=dword:00000001
"UseDX9LText"=dword:00000001
"BreakOnUnexpectedErrors"=dword:00000001
"RPCAvalon"=dword:00000001
"RecordAvalonFile"=dword:00000000
"UseReferenceRasterizer"=dword:00000001
"SkipDriverDateCheck"=dword:00000000
"SkipDriverCheck"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Avalon.Graphics\DISPLAY1]
"PixelStructure"=dword:00000001
"GammaLevel"=dword:00000898
"ClearTypeLevel"=dword:00000064
"EnhancedContrastLevel"=dword:00000190
"GrayscaleEnhancedContrastLevel"=dword:00000190
"TextContrastLevel"=dword:00000002
Varadharajan K
JedG_Intel
Hi MyTimeTheBest,
I'm just following up to see if the recommendations from VARADHARAJAN worked for you? Please let me know if you need further assistance to I can continue addressing your concern.
Jed G.
JedG_Intel
Jed G.
