hello i'm using an external monitor and i can't use saturation the well-known "digital vibrance" i'm using a hdmi-> vga converter only YCbCr appears I don't want to stop using this monitor can someone help me
AFAIK, that converter - and in essence your ancient monitor - are the limiting factors. Let's go through the analysis regardless. What is the model of your monitor? What is the HDMI-to-VGA adapter that you are using? What is the model of your laptop (or, if desktop, motherboard)?
Please download and run the Intel System Support Utility for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't attempt to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for your response, upload and attach this file to the response.
