22944 Discussions
Saida HDMI Intel Graphics HD 3000
ATorr8
Olá, tenho um note Positivo com uma placa Intel Graphics HD 3000 e não consigo ligar o Note a TV via HDMI, se desinstalo o driver da placa funciona normalmente. Se instalo o driver não funciona a saida HDMI.
Quando instalo os drivers e reinicio o Note a imagem aparece até a inicialização do Windows e depois fica sem sinal.
Se desinstalo o driver e reinicio o Note, funciona normalmente.
Alguém pode me auxiliar?
Grato.
Alan Torres
Hello Alan_Torres,
Thank you for contacting the Intel community.
Could you please provide us with your system model, processor model and system maker?
Also, I will appreciate if you can provide us with the TV model and the operating system you have installed.
Ivan.
ATorr8
Olá, seguem as informações solicitadas.
Máquina: Positivo Premiun N8575
Sistema operacional: Microsoft Windows 7 Ultimate (32 bit) Service Pack 1
Memória: 6 Gb
Processador: Intel(R) Core(TM) i5-2410M CPU @ 2.30 GHz
Placa Gráfica: Intel(R) HD Graphics 3000
Versão Driver:9.17.10.4229
Televisor: TV Led 32" HD CCE LT32D com conversor Digital e Entradas HDMI e USB
Grato
Alan Torres
In this case, your best contact support is with your computer manufacturer as they are more familiar with your PC and how the components interact with each other. Contact your computer manufacturer, and have them verify the proper working functionality of your system.
However, you can try the following:
  1. Check all connections to make sure there are no loose cables.
  2. Unplug the HDMI cable and plug it in again. Do not use any adapters; make sure you use straight HDMI connection.
  3. Check that the port is not disabled in the BIOS.
  4. Try troubleshooting using a different HDMI port or cable if one is available for you.
If the above does not work try this:
Update the System BIOS via the instructions and BIOS software provided by your computer manufacturer.
Note: If you are attempting to connect to a TV that supports 1080p, 4K, 3D or Deep Color, you will need to use a High Speed HDMI Cable. To verify you have one of these, look along the cabling itself for the printed text which says "High Speed HDMI Cable." If it is not there, you may not be using a cable that is required to work with your display device
If nothing works, try uninstalling the graphics driver and reinstall the Intel® generic driver manually, you can download it here:
https://downloadcenter.intel.com/download/24970/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32bit?product=81500 https://downloadcenter.intel.com/download/24970/Intel-HD-Graphics-Driver-for-Windows-7-8-8-1-32bit?product=81500
Please see http://www.intel.com/content/www/us/en/support/graphics-drivers/000005598.html Uninstalling the Intel® Graphics Driver and Intel® Display HDMI/Audio Driver and check http://www.intel.com/content/www/us/en/support/graphics-drivers/000005474.html How to Manually Install a Graphics Driver in Windows 7*
I hope that can help.
Ivan.
ATorr8
Olá Ivan, boa noite.
Agradeço pelas respostas, porém ainda não obtive sucesso.
Volto a informar que se eu desinstalo os drivers, funciona normalmente e após a instalação dos drivers, para de funcionar.
Gato.
Alan Torres
At this point, I strongly recommend contacting your system manufacturer as they are more familiar with your system and how the components interact with each other, your computer manufacturer will be able to help you with the right configuration on your laptop.
You should be able to get the right support here:
http://www.positivoinformatica.com.br/suporte-tecnico-drivers# tab-computadores http://www.positivoinformatica.com.br/suporte-tecnico-drivers# tab-computadores
NOTE: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
I'm sorry that the troubleshooting steps I provided did not work for you and hopefully your computer manufacturer will provide you with better support.
Ivan.
